Question about Onkyo TX-SR605 Receiver
Video blanks out TX SR605
I have been seeing an issue lately when playing games on my xbox 360 connected with component to my receiver and then component to my Samsung rear projection tv.
During game play the component connection will refresh and go blank to resynch the video display, the comes back. This can happen several times in 10 minutes or not at all until about 30 minutes of play. One thing I am going to try will be to remove the video connection from the receiver and connect directly to the TV. Any assistance would be appreciated as this has only become an issue in the last 2 months. I have had the receiver and xbox since March.
I had the same thing happen with my SR705. I ended up hooking the video to the tv and leaving the audio to the receiver. Haven't had trouble since
Posted on Aug 15, 2008
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Onkyo sr605: needs to "warm up" before video
check your display section, is there any problem?
Jan 08, 2011 | Onkyo TX-SR605 Receiver
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
I have an Onkyo TX-SR605 AV receiver that just stopped outputing video to my Panasonic projector. I have connected other devices directly to the projector and video is fine, so the problem is not the...
Goof information. Have you eliminated or proven the Onkyo as a cause by going direct to the projector? Try another Input and/or Output. It's best to know which component is broken and if it's limited to a specific subset of its function.
Settings are also indicated. Run through the video setup again. If it just stopped, what preceded it?
Nov 27, 2009 | Onkyo TX-SR605 Receiver
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Dec 11, 2007 | Onkyo TX-SR605 Receiver
HDMI audio source issues with television off or set to different source?
It is related to the tv, modern tv's have the ability to control different devices through the infra red pick up on the tv, and pass it through the hdmi cable back to the component.
Sony call there remote link Bravia link.
Check your manual for that, If it doesn't tell you anything, then don't worry about it, if it is in the manual then see how to switch it off.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Nov 29, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver HDMI Issue
How good are the hdmi cables that you are using???
Nov 26, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
102 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
