Question about Sharp AR-160 Copier
Reset button Does this copier have a reset button?
  • Sharp Expert
  • 1,326 Answers
A reset botton for what???? A error code or just to clear the control pannel?
Posted on Jul 25, 2008
Where is reset button
Printers and copiers usually don't have a reset button. You have to turn them off (power down) and turn them on again to achieve a reset. What is the reason you want to reset the device?
Jul 02, 2015 | Office Equipment & Supplies
How do I reset 2nd bias transfer roll for xerox 7556
On the 7556 and most other Xerox copiers, follow these steps to reset the counter. You do NOT need to call out a tech.
The supply life counters must be reset when some supplies are replaced.
  1. Log in as the System Administrator or Key Operator.
  2. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed.
  3. Select the [Tools] tab on the Touch Screen.
  4. Select the [Device Settings] button.
  5. Select [Supplies], and then under Features select [Supply Counter Reset].
  6. Select the required supply item, and then select [Reset Counter].
  7. Select [Reset] when the confirmation screen is displayed.
  8. Select [Close].
  9. Press the [Log In / Out] button on the Control Panel. The Logout screen will be displayed.
  10. Select the [Logout] button on the Touch Screen to exit.
Feb 11, 2013 | Xerox DocuColor 3535 Copier
Ink absorber almost full
unplug the printer, then press Stop/reset button, the plug the printer, while pressing Stop/reset button, press the power button, then release the stop/reset button, still pressing the power button, then press the Stop/reset button ( 2 ) two times the release the power button and stop/reset button. the run the service tool_V1050 exe.
Sep 11, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Errer code 5
1/ Turn off the canon printer
2/ Hold down the Stop/Reset button
3/ Not releasing the Stop/Reset button, hold down the Power button, now release the Stop/Reset button
4/ Not releasing the Power button, double click Stop/Reset button and release both the Power & Stop/Reset button - doesn't matter in which order
5/ Click Stop/Reset button four times
6/ Click the Power button to confirm the selected action (reset counter absorber)
Aug 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
How to reset error E5 on nashua coprier
theres no e5 on aficio 450must be sc542/546 problem with heater try to reset code press yellow
button then 1 0 7 then press red button keep the red button held down 4 secounds then select
copy 1 turn copier off then switch back on
Nov 11, 2010 | Ricoh Aficio 450 Copier
How do you reset the savin 8035 sc542 code after thermistor is replaced?
Press the yellow button ( reset button ) then press 107 then press and hold the red button (stop button ) for about 3 sconds until the display changes. Touch copier on the display screen. Now turn the copier off using the on off switch on the left front side of the copier. If the cold comes back the Thermostat in the fuser is most likely tripped and would need to be replaced.
Apr 29, 2010 | Savin 8035e Copier
Pm reset
F7-03, have a service technician clear/reset the PM count. NO reset button
Sep 03, 2009 | Panasonic Workio DP-2000P Copier
H-4 model xc830 copier
Performing a Fault Reset 14 will reset your copier and will help to clear error codes. 1. Turn the power off. 2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button. 3. Locate the Auto Button the lower left corner of the Control Panel. 4. Turn the power back on. 5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear. 6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5. 7. Program the copier as if you were going to make 14 copies. 8. Press the green [Start] button to store the reset code. The copier will return to the ready position. 9. Run a test copy.
Jun 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
How do ya reset fuser code (H-4) Xc1044 Xerox?
  9. Run a test copy.
Nov 26, 2008 | Xerox Office Equipment & Supplies
Sharp AR-160 Copier Logo
49 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
