Question about HP Officejet 5610 All-In-One InkJet Printer
Scanning problem I just got a replacement of this product and the same problem perisist, even worse. For almost a year now, i'm not able to use the scan function on my HP 5610. I keep getting th emessage " cannot detec scanner" or someting similar. But in addition, the solution centre does not display anymore. When i click sol.center i get the msg, "no hp device detected" can you help. Its so frustrating.
  • Hadassah20 Jul 24, 2008
    I used the driver that came with the equipment. Should there be any other driver? If so where can i get it? By driver i presume you the CD that was supplied with the equipment.
  • 446 Answers
It means that there is no presence of a particular device detected, kindly reinstall the drivers again, make sure the right model for the right driver, this should work
Posted on Jul 24, 2008
In need of the panprint01 driver, lost the cd ... help please
Go to the product support website of the maker of the printer to download the printer drivers. Also in the future always in include make and model of the printer.
Jan 10, 2017 | In Office Equipment & Supplies
I want to show a 6% sales increase from last year to this year. How do i figure it?
take you sales for the last year and put it into a calculator, then press plus + and then 6 and then the per cent key %
Or
Take your sales from last year, multiply by 6 and then divide by 100. That is the amount you will increase. Add it to last years sales.
Jan 09, 2017 | The Office Equipment & Supplies
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
How do I get msds sheet for this product?
If whoever made that product made an MSDS sheet, then it could be listed in the following database: http://www.msdssearch.com/msdssearch.htm.
Feb 26, 2015 | Seiko Smart Label 420 Thermal Printer
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Commutative property of multiplication 3*7*2=
If there was a question it is not clear. I will show you what commutativity works. Whether that answers your lack of question remains to be seen.
Commutativity of multiplication (or the commutative property of multiplication) means that the order of the factors in a product does not affect the result. In other word, the order of factors is unimportant.
3*7+2 =7*3+2=23
2*7*3=2*3*7=7*2*3=7*3*2=3*2*7=3*7*2=42
Mar 28, 2014 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
50 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
