Question about Minolta Office Equipment & Supplies
I am using the combination feature: I am putting two pages on one but it is putting page 1 to the right and page two to the left. Can I get it to put page 1 to left and p.2 to right?
  • 446 Answers
Change the orientation of your desired original
Posted on Jul 24, 2008
Where to plug the f_panel power cable
No I do not.
ECS Support does though,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=830&CategoryID=1&MenuID=16&LanID=0
Click on the Download tab.
(Features / Specification / Download / FAQ / CPU / Memory )
Click on Manual
(Driver / BIOS / Manual )
Scroll to the bottom, click ON the country name nearest yours.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up.
Go to the Bottom/Middle of the page with your mouse cursor. The ghosted out navigation guide will appear.
Go to the far right, and click on the Adobe PDF icon.
(When you hover your mouse cursor over it -
Show Adobe Reader toolbar - will briefly appear)
The Zoom In icon ( + ) increases the view size, if you click on it.
The Zoom Out icon ( - ) decreases the view size.
The PDF file page number box is to the right of the Down Arrow.
The PDF file page numbers, and the motherboard manual page numbers, do Not match.
When I refer to a page it is the PDF file page.
If you know the page number you want, you can go page by page, using the Down Arrow to arrive at it,
Or;
1) Put your mouse cursor in the PDF file page number box,
left-click once. (Anything in the box is now highlighted in blue)
2) Type the page number
3) Press the Enter key.
Go to Page 10. Motherboard Components.
Motherboard installed in your computer;
Processor to the Top, Ram Memory slots to the Right, and white PCI slots to the Bottom;
The Front Panel header is at the Bottom/Right corner. (8)
Go to Page 33. Front Panel header pinout.
The Front Panel header lies horizontal, and parallel to the bottom edge of the motherboard.
It is two rows of contact pins.
The TOP row is numbered EVEN.
The Bottom row is numbered ODD.
Starting from the LEFT side going towards the Right, for the Top row:
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting from the LEFT side going towards the Right, for the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the two wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It was for factory use.
D) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 22, 2012 | EliteGroup Computers & Internet
I'm trying to photocopy a book on a canon imagerunner 5075 without copying one page at a time and flipping the book around. Is there a way where the copier scans the right page and then scans the left page...
Hi Kim,
there are a couple of easy ways to tackle this problem. you have a book that when the spline is opened exposes 2 pages to the glass for the possibility of copying. What YOU need to determine is whether or not you want page 1 to ouput seperately from page 2, or , would you like page one to be on one side and page 2 to be on the second side. In other words auto duplex. That decision determines which feature you will use. I will walk you thru both. I realize you want the copier to scan the first page and then scan the second without you having to move the book around. I'm thinking you would be happy if the copier did that very thing and you wound up with a 2 sided copy with page 1 on the front and page 2 on the back. Here we go. Fom the main copy display locate the 2 sided button and select it. Select "book 2 sided" and follow the prompts. You could actually copy the entire book this way and when you are thru press "done" and here comes the avalanche!
If you want the images 1 sided on seperate sheets (not sure why) you can select "special features" from the display in the lower right corner and select "2 page seperation". same drill.
Apr 25, 2011 | Canon imageRUNNER 5000 Copier
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
I have aopen ax4bs motherborad and i don't know where the power sw goes
If you look at the picture below, I have circled in red the two parts you have to connect for your power supply to the motherboard.
Nov 24, 2010 | AOpen AX4BS Pro (91.89J10.001) Motherboard
What is the best setting on adell 24
The issue is relative to the native resolution of the monitor. in most 24" monitors the resolution is 1920 x 1200. When you get an application that is shown in the upper left corner of the screen, it is most likely set in a page frame of 800 x 600 or 1024 x 768. Also many web pages will display with large amounts of white space on one or both sides.
This you can do to help.
Set the DPI setting in display properties to 120 will help some making small type more readable.
Pages that are in Internet Explorer can be zoomed to appear larger zoom feature in bottom right corner of IE window (or CTRL & + and CTRL & - key combinations)
Oct 03, 2009 | Computers & Internet
Copy pages from book
depends on the copier most if you place the book under the doc feeder and put the first page to be copied with the edge on the position plate you copy theat page and then move the boo over so the centre is on the edge of the glass copying are it should copy that page .. if you hve a large copier if you put the book in the centre marker and select the combine book feature it will scan all the book put one page on one sheet and the other after .. can you put up the details of your machine for us
Jun 23, 2009 | Office Equipment & Supplies
Want to scan several pages as one pdf document
Try OCR Terminal,which is an online OCR service that converts scanned images into searchable text. Register an account and you can convert 20 pages for free every month.
Have a try and hope it helps.
Mar 30, 2009 | HP Officejet J6410 All-in-one InkJet...
Over-ride toner page counter for printing
You need to enable the cartridge out override:
1. On the control-panel menu, press OK.
2. Use the Left arrow ( ) or the Right arrow ( ) button to select System setup, and then press
OK.
3. Use the Left arrow ( ) or the Right arrow ( ) button to select Print quality, and then press OK.
4. Use the Left arrow ( ) or the Right arrow ( ) button to select Replace supplies, and then press
OK.
5. Select Override out to enable the feature. Select Stop at out to disable it.
Mar 25, 2009 | HP laserjet Cp2025dn color Card Printer
Intercom
Are you referring to page all phones?
you have to put all phones into a ringing group first.
From extension 10 or 11
Feature 00
Left intercom
Left intercom
Press #502
At the group prompt, enter the group number you wish to use (1-4)
At the extension prompt, enter the extension number you wish to add to the group
It will say 1-assigned or 2-not assigned
Press 1 to assign it to the group
Repeat for all extensions
Feature 00 when finished
Now, to page the group, you will press "Intercom *7x (where x is the group number)
Example, Intercom *71 to page group 1
If you wish to put that on a button, you must go to each phone.
At each phone...
Press Feature 00
Press the button you want to program
Press the LEFT intercom button and *71 (for group 1)
Feature 00
Repeat at each phone you want the button on.
Sep 29, 2008 | Lucent PARTNER18 Corded Phone
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
