Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Printer doesn't respond to computer
Hi! I'm Rina.
My canon printer doesn't print at all. It is installed on my computer but each time I print it would say "printer not responding." I tried using another cable into the different ports but it still doesn't do anything. Please help me!!!
  • teardrops27 Jul 24, 2008
    Thanks for trying!!!
    I tried switching from one port to another but nothing happened. It always says error. What could be the problem? the printer just doesn't respond at all!
This problem happened to me. You have to find the right COM port that the PC assigned to your printer. Go to " Control Panel" and find the "printers" and add you printer using each time different COM port. After each addition, try tp print and see.
Posted on Aug 10, 2008
  • 446 Answers
There were many instances why the computer says "printer is not responding" either it is not configured correctly. for a start..
try this go to start- printer- right click the desired printer- open up properties- then click print test pages-
if it does print then it should work on all platforms, if it doesnt then you might have installed the wrong drivers.
try this first
Posted on Jul 24, 2008
Printer not responding?
Try removing the printer and re installing it. Sometimes computer updates can cause errors.
Jun 12, 2012 | Canon PIXMA MP240 All-In-One InkJet...
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hi, i have some problems with my ML-2010R, it doesn't respond to anything from the computer. when i press ON it makes the usual noises,eating and preparing for printing , but when i try to send a file...
try to use a new USB cable maybe the problem is on the cable this transfers the data from your PC to the Printer this is a common issue for printers. Or update your printer driver.
Sep 02, 2011 | Samsung ML 2010 Laser Printer
My canon mp800 printer, is saying printer not responding when trying to print
hi..
1.unplug the cable then plug it ...
2.did u reinstall it? try to remove it on ur computer then re-install it..
hope helped u
regards..
Jul 12, 2011 | Canon Pixma MP800 All-In-One InkJet...
My Canon Pixma IP 2200 Inkjet Photo Printer won't respond to any printing commands. It is installed in my programmes. I have tried troubleshooting re setting but it still won't work.
Bottom right of your computer screen where your speaker icon would be? Is there a printer icon?
Printers will buffer (collect) till they can be printed. even if you shut down your computer and restart, these buffered print ques may not leave - printer traffic stops on this first print in the Que.
Right mouse click this printer icon and open all active printers. if there is more then one in this buffer, then select all of these and cancel them..
If this doesn't help and your USB and power cables are connected then unplug your USB cable and wait about 10 seconds and then reinsert your usb cable - see if your computer responds by indicating your printer has been identified. And try printing then.
Best photo printing and general use printing. Canon
Thank you for your Visit to fixya.com
Nov 15, 2010 | Canon PIXMA iP2200 InkJet Photo Printer
Resume not working
Sounds like head failed replace it see below
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Oct 23, 2009 | Canon BJC S300 InkJet Printer
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Free driver for canon printer ip1880
I want to install cannon iP1880 printers software.please letus know how to installed
Mar 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
343 people viewed this question
old marine
old marine
