Question about Miele WT945 Front Load Washer / Dryer
Miele WT945 Rinses Light is flashing : I read an online forum in UK that said this means a new motor is required - cost prohibitive. I rang Miele - they say it is not always the case - could be electrical fault - Is there anything I could do to check and save a £99 call out fee? thanks
Programme won't move on - rinses flashing and programme won't continue
Hi dear. Regarding your information, I would say 3 factors play up with it.
1- Tacho generator or it's plug faulty on motor
2- Motor Carbon brushes worn out or
3- Power/control unit faulty.
I can advised to contact your local Miele center to diagnose your machine.Thanks.
Apr 17, 2016 | Miele 300 Front Load Washer
Miele WT945 drier removal
Hi dear.
It is very complicated work. I can suggest you should not involve doing that but if you know what you are doing try that out. See if it helps.
Common problem: Stuck drying air fan shaft.
1- Unplug machine from power. Remove top cover.
2- RHS at the back,on outer drum horizontally mounted motor,drives a belt.
3- Try to rotate motor shaft (impeller) by hand, see if it's hard to rotate. Try to make it free to rotate.
3- If you have a capacitance meter, check value of capacitor should be in range of 2.5 uF if not replace capacitor.
Beyond that you need to get tech. to assist your machine. I hope that helps so far. Thanks.
Feb 25, 2016 | Miele WT945 Front Load Washer / Dryer
How to change the heating element on miele wt945
take the back off the heater has 1 10m nut in the middle and 2 wires on it take off wires undo 10m nut prize off the heater it is compressed in a rubber it might take a bit of force the best thing to do before this is to test the heater with a multi meter 1st if there is no reading across the two terminals the heater has gone get a new heater and have a look at it you will see what holds it in
Sep 26, 2012 | Miele WT945 Front Load Washer / Dryer
The buzzer sounds and the rinses indicator light flashes and the programme sequence display " - - - " appears in the display. This occurs at the end of all programmes just as it starts to spin.
Hi - I will tell you whats wrong with the machine, but you will need to get someone familiar with Miele equipment to fix it for you.
On this particular series - Rinse LED flashing means 3 - 4 things could be wrong with the washer.
Tacho - generator is faulty
Drive fault - electrical problem
Motor - has issues with starting
Blockage - drains - drive unit
Restrictions - of the drum turning.
Electronics - may be a component with an intermittent failure/decay.
It would be either one of the above or a combination of 1 or the other...
Jun 20, 2011 | Miele W435WPS Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele WT945 leaks water from internal drain
Hi
If it is the bottom hose on the condenser box leaking.
This is a vent.
It is most likely the condenser box is blocked with fluff and will require cleaning or replacement. I imagine the appliance is not drying very well if at all
Apr 02, 2010 | Miele WT945 Front Load Washer / Dryer
Rinses light flashes miele w864
this usualy indicates a problem with the motor not turning, it can have many causes
Jun 28, 2009 | Miele W864 Front Load Washer
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele WT945 Front Load Washer / Dryer Logo
463 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
