Question about Zenith C27A24T 27" TV
Missing Channels I just purchased a Zenith 27" from a frien and hooked it to a cable cord; no boxes and the channel starts at 48 and up. I cannot receive any of the lower channel. We went through start up and it shows channels found, but nothing seems to appear. Can you help with this?
  • escriven Sep 28, 2008
    bought unviversal remote. can't access menu button. can only get approx 20 channels but in random order. pluged in vcr didn't help
  • Anonymous Mar 14, 2014
    how to fix missing channels on 209 zaaptv ? every time i lose a channel from my zaaptv box
  • 30 Answers
You may have a bad tuner that is the part that changes the channels. If there is the input jacks you can use them to input a VCR or cable box and use them as a tuner
Posted on Jul 26, 2008
Does the Zenith A27B33W need a digital converter to get broadcast television? (not cable TV)
Turn on your Zenith TV and try selecting channels. If you see channels such as 10.1, 52.2, etc. displayed, they are digital. If you do not see digital channels displayed, you will need to purchase and install an A/D converter (set top box).
Feb 23, 2015 | Zenith A27B33W 27" TV
I have a zenith 27 inch tv I purchased today from Hollywood Video because they were going out of business. Well the only problem is that I have tried with a universal remote and the original panel on the...
hopefuly it has more than an NTSC tuner .... see if you have a setup menu on the set ... if so start it to automatically search for channels ..if its doesnt find any or if it finds limited channels then you may need an external box .most cable channels are now digital as are most off the air stations ... if your set has a digital tuner then it still might not be able to pick up all the cable stations but should get some that are within its tuning range... if you can give a model number for your zenith then its capabilities can be determined ..
Apr 10, 2010 | Televison & Video
The socket for cable hook up is broken off how do i fix it
As costs of repairing a TV can get expensive here is a quick and inexpensive fix.
1) Get a VCR and hook the cable into it and then connect the VCR to the TV with RCA cables. Now days you can get a VCR pretty cheap at a thrift store or a pawn shop then use the tuner in the VCR to change the channels.
OR
2) Get a digital cable box from your cable provider and ask to have it hooked up with RCA cables. This option avoids the need for the cable jack and get to take advantage of the digital channels.
Good Luck...
Jan 19, 2010 | Zenith B27A11Z 27" TV
My old zenith (probably early 90s) only gets up to channel 48 when there are more channels provided by my cable service. I have used the autosearch, and thats what number it goes to.
[1] use LG exteanel setup box chenal convater 90 to 200 ch avalabel in market .
[2] use inside of tv extra chenal convater pcb. PHLIPS.
[3] change complet new tv chasis with new latest function and all new facilety
EXP.
UOC Technologey chasis
NTSC /PAL /SCAME / AUTO Multi Colour System
Auto Search tunig
A/v 1 -2 -3 Stereo.
A.v Out facility
DVD Comonent input
surround sound mode
1300w pmpo woofer System
on timer /off timer /clock /sleep timer facilety
calender
5 pictur mode
Curtain Effect.
all facilety Avalabel in TOSIBA /SANYO chesis
pls Cont. your Nr.tv techicien
Oct 30, 2009 | Zenith C27A24T 27" TV
DTV converter Box and Zenith system 3
I have the same problem.... On the back of the tv, there are three coax spots. One is for Cable, one is antenna decoder, and another is a loop. I have had zero luck getting any of those to receive the signal. Instead i have ran my digital signal to a vcr, then ran rca cables from it to my tv. I then put my tv in vcr mode, or aux depending on where you hooked it up. You can watch tv through your vcr this way.
Oct 10, 2008 | Zenith C27A24T 27" TV
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Zenith SR2075DT 1995 TV
In your on screen menu have you gone to set up? Here you would select cable and not off air and then do an automatich channelprogramming. I hope this helps.
Sep 10, 2008 | Zenith C27A24T 27" TV
Fuzzy pictuore
It's maybe because you are an idiot. "P-i-c-t-u-r-e.
Jun 08, 2008 | Televison & Video
Zenith tv
well 2 things come to mind, 1st go into menu and run channel scan, see if that brings them back
2nd if you see a black square on the screen of these channels turn off the closed caption, again in the menu
and if all else fails hook up cable or sat box from the video out to the video in on the tv, set the tv to video input viva remote or going to channel 00
hope this is of some help
Feb 06, 2008 | Zenith B27A11Z 27" TV
Hooked to cable...says no channel found
how old is this set? there were some certain years the auto matic scan didn't work, you must enter them under the manual way.
Nov 19, 2007 | Zenith A27A23W 27" TV
Zenith C27A24T 27" TV Logo
66 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
