Dcp115c brother unable to clean
Need resett procedure my printer is brother dcp-115c and the error message is "unable to print"..what is the solution?i tried the solution for the error unable to clean but no luck..
  • dycoy24 Jul 24, 2008
BROTHER INTERNATIONAL
ATTENTION: CoDEC0012 "JOHN" email oblacks_pit@yahoo.com
UNABLE TO CLEAN?
1. TO ENTER MAINTENANCE MODE: PRESS MENU, MONO START, 4X ON ARROW UP (WITHIN 2 MINS)
2. USING ARROW UP BUTTON LOOK FOR THE FOLLOWING
a> 8 then press SET
b> 0 then press SET
3. USING MONO START, JUST PRESS IT UNTILL THE WORD "PURGE XXXXX" COMES PUT.
4. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING: "FLUSH"
A> 2 THEN PRESS SET
B> 7 THEN PRESS SET
C> 8 THEN PRESS SET
D> 3 THEN PRESS SET
THIS IS TO RESET THE PURGE COUNTER
5. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING
A> 0 THEN PRESS SET
B> 1 THEN PRESS SET (TO RESET UNIT)
C> 9 THEN PRESS SET
D> 9 THEN PRESS SET (TO EXIT MAINTENANCE MODE)
THAT'S ALL FOLKS JOHN
Posted on Aug 15, 2008
Brother dcp115c unable to print error
High probability it is a waste ink count or "error 46" code fault. There are purge count reset codes available on line, but you should also remove and clean out the waste ink chamber. It is a messy job and given the age of the machine, you may be better off replacing it
Nov 12, 2017 | Brother DCP 115C All-In-One InkJet Printer
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
May 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message
printer brother dcp 115c .unable to clean. what must i do
Jan 19, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brothers dcp115c
search fixya forum for error 46. you need a new waist ink absorber box!
Jun 15, 2008 | Brother DCP 115C All-In-One InkJet Printer
DCP 115c How to disable auto cleaning?
did you already install your printer to the PC ?? have the installation disc ?? if yes , go to MY COMPUTER , DO A RIGHT CLICK at the icon of the printer and click PROPERTIES ,THERE you should be able to disable the command .
Apr 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
My printer have problem
you need a new waist ink absorber box.
Search this forum for error 46 or unable to clean. the procedure is explained many times (identical for all brother inkjets)
Apr 17, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother dcp115c
cause the waist ink absorber box is fed up with ink. you have to replace the box and to reset the eeprom. search error 46 or unable to clean here. its written very often how to do that (same procedure for all brother inkjets)
Mar 17, 2008 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
543 people viewed this question
k24674
jasbo
jasbo
