My Philips TV is clicking off then on again. Not often, it's been happening in the last couple of days. Could this be a fire hazard? Thank you
My son wants me to contact Philips. Thank you anyway, maybe some other time.
Posted on Jul 25, 2008
Hi I have a Philips 40PFL3705D/F7 LCD TV. The picture shuts down after a while. Could be 3 weeks, 3 days or 3 hours of watching TV. Still have sound.
Maybe a thermal problem or there is something apart loose even use cold spray, manipulated by slight shaking or tapping components.
Oct 31, 2015 | Philips Televison & Video
I have an lg 52lg50 lcd tv. for some time now the switch just repetitively clicks until the tv eventually comes on. the last couple of days, it doesn't come on at all - it just carries on clicking. is...
Hi, I've had that happen with TVs before, it tends to be caused by blown capacitors on the motherboard. It can be fixed however it's not something you could easily do on your own, you'd want to take the TV to a local repair shop, I've seen the repair range from $50 up to $250 or so in my experience.
Aug 29, 2011 | LG 52LG50 52 in. LCD HDTV
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
My Philips TV will not turn on
More than likely it's activating the protection circuitry. Most of the time televisions won't give you a sign of trouble until something actually breaks. One day they work and the next they might not. There could be a problem in the power supply or the scan section which are both internal that would inhibit operation to prevent your set from overheating and causing a problem external to the TV like a fire. If your set is over 10 years old, replace it. If it's quite new but out of warranty then get an estimate at a reliable electronics repair store.
Mar 30, 2010 | Philips Televison & Video
Burnt electronic smell even hours after tv turned off
Its behavior is not normal. Have it repaired. Fumes are hazardous to your health especially to the little one's health. Think of a fire hazard too. As the adage says :No fumes without fire.
Hope you decide to be rid of the bomb or have it repaired.
Sep 05, 2009 | Sony KV-27V22 TV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 27PT643R37A switches on and inmediatelly off
i had same...power supply board shortage...find short or replace board...replaced board here
Jun 28, 2008 | Philips 27PT643R 27" TV
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Phillips TV not really turning on
You can try to check if these are a couple of bad solder joints on the board. You might have alot of dry joints. Take carethat the tv is unplugged and try it out. before starting, try shorting the pins of the largest capacitor in your tv set, to make sure you do not take an electric shock. Best Regards Patrick
Feb 16, 2007 | Philips 30PW633R 32" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
