Question about Dell PowerVault 100T DAT72 DAT Tape Drive
Dell Dat 72
It keeps spitting the tape back out, and the cleaning light is blinking..I have ran a cleaner tape thru it as well
  • perr0117 Sep 10, 2008
    From day one the darn thing has been giving us problems. Not like our HP DAT 72 drive which we went through 4 of them until the problem was solved. We run the cleaning tape three times and run, we run the cleaning tape three times a week. still the same problem and darn cleaning tapes are not cheap. So if its a cleaning or media problem how come the problem stopped with the fourth HP drive? Dell needs to come up with some solutions or I am thinking that this product is best avoided.
  • Anonymous Jan 29, 2009
    We are having the same problem. Unfortunately, I can't really tell if the cleaning tape is running at all or if it is just being ejected after a few seconds.
I did some checking on Dell's site and noticed there is a firmware update dated 4/18/2009. One of the issues it addresses is excessive cleaning light issues. I am scheduling a maintenance window with my client and will see if this fixes this issue.
Posted on Oct 23, 2009
The cleaner tape was brand new
Posted on Jul 29, 2008
Try a different Cleaner tape, they dont last forever..
I getting clean light on HP dat drive? please help .
You need to load a Cleaning Tape into the drive. Tape drives have special tapes just for cleaning.
Jan 04, 2011 | HP StorageWorks DAT 72 Tape Drive
Anytime I try to backup or copy a 33GB data file on a 40GB or 72GB Data cartridge, it requests for more data cartridge even after formatting the data cartridge prior to starting the process. Sometimes, the...
Because the DAT72 can copy 72GB with 2:1 compressed, and it's native capability is 36GB in the most. So you can try to copy less than 30GB data to it or try to enable the drive's compress mode.
Nov 26, 2010 | HP StorageWorks DAT 72 Tape Drive
Cleaning light always on
Perform the cleaning action using a new cleaning tape. It is not recommended to clean the tape over and over again, if the cleaning light is still ON. Contact the vendor and get it sorted out.
Please coem back and rate the solution if this turns to be helpful for you.
Thnx
Mar 22, 2010 | Dell PowerVault 100T DAT72 DAT Tape Drive
The
Clean the drive 5 times in a row with a non expired cleaning cartridge
Nov 16, 2009 | HP Compaq StorageWorks DAT 72...
Certance DAT 72 tape drive stopped communicating with PC
We have had the same problems with HP drives and Veritas. In our case it was not the drive per se. While I am assuming that based on the date of your post that you have moved to another solution, however, I will provide for you what we did.
First shut all down, disconnect the tape drive from the scsi cable, then restart. Go into computer management and turn all your backup exec services from auto to manual. Now go to devices and do a rescan. Once this is done and you see no tape drive whatsoever in the devices shut down the server. Reconnect the scsi cable to the drive and restart.
Go back into computer management, back to devices and rescan for hardware changes. Do you see it? If so, good! Sometimes a re-seating of connectors will do that. On the other hand, it could also be a tape driver from Veritas that just doesn't work (my case), take the original driver cd that came with the unit and start that loading up. Can you see it now? Can you use windows backup to access the tape drive? Now go into services and start the services individually. Go into backup exec and see if you can read your tape. Go back to services and reset all services back to auto. If you ever have to reinstall/upgrade backup exec, think twice about using their drivers.
Nov 12, 2009 | Certance Internal DAT 72 (cd72lwh-s) DAT...
Dell dat 72 drive will not accept a tape
power off and on the tape drive
Inset a NEW Fresh out the Wrapper cleaning tape and see if that works!
Sounds to me like your existing cleaning tape has expired
If that fails then there could be a problem with the loading mech which is where you will need to send it away for repair.
Try www.tape-drive-repair.com for this as they are not expensive
Dec 09, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
Wont accept cleaning tape
Make sure there are no pending jobs on the drive, if the drive is expecting a tape and gets a cleaning tape it will spit it out. Also, has the cleaning tape been used a lot? They have a limited life cycle and if they have exceeded their max uses they may not work.
Nov 13, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
Constant Cleaning of new PowerVault 100T DAT72
Tape drives do need cleaning frequently and the 'auto clean' facility may not be enough. The problem is the continuous shedding of oxide needs cleaning right off and the auto system may not be enough. What you need is a back-up Drive. and the out of service drive needs physically stripping down to clean all off using a soft brush and where appropriate coproponal alcohol
Jun 13, 2007 | Dell PowerVault 100T DAT72 DAT Tape Drive
Dell PowerVault 100T DAT72 DAT Tape Drive Logo
1,022 people viewed this question
Alun Cox
