Question about Canon Rebel XT / EOS 350D Digital Camera
Flash Problem Rebel XT flash icon shows next to "busy" in the view finder when I press the shutter button. If I attempt to take the photo the flash does not work. If I continue to hold the shutter half way down, then release it I get Err 99. I am using genuine Canon lens' and have tried all three. I also connected my 420EX external flash and it also does not flash. Any suggestions are deeply appreciated. Thanks
  • millieed Dec 03, 2008
    I am also getting the flash sign with "busy" next to it, but haven't had problems taking the photo. My problem is my screen will no longer preview the photo - it was until last week.
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey tombston,
An error code of 99 is Canons general error code for this camera, and they suggest cleaning the lens contacts and/or removing the battery and then reinserting it. If this doesn’t work I would try resetting the camera to the default factory settings, and directions on how to do this are on page 35 of your camera manual. If this doesn't work I would have the camera looked at by an authorized service technician. I have included a link to a PDF download of the camera manual in case you need it. I hope this helps!
Go Ahead. Use Us.
Posted on Jul 24, 2008
Reble xt flash will not pop up why?
It depends on what setting your main top dial is set on? The flash will not pop up if you have your main dial set on P, Tv, Av, M, A-DEP . If you are using one of these setting you have to manually turn on the flash by pressing the small button on the side of the lens with a Flash icon next to it.
The only time the flash will automatically pop out is if you are using AUTO, Portrait, Close Up...etc. these icons would be underneath the Auto setting which are called Scene Mode, hope this helps ?
Jul 07, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel XT Error 05 or BUSY
The Error 05 means the build in flash cannot be raised.
In the moment it should pop up, something was blocking the free movement. Could be caused by the way you were holding the camera. Could be happening, while you were pressing the flash button, or when you are in the basic zone shooting mode, such as portrait, which needs the use of the flash.
Switch the camera off an then on again. Move an eventually cause of the blocking and press the shutter realise button again.
Feb 21, 2014 | Canon Cameras
Flash won't work...flash icon on screen flashes when shutter button is depressed
try a reset of all options to default. It's possible that it has been set accidentally wrongly
Nov 09, 2013 | Canon Rebel XT / EOS 350D Digital Camera
There are two problems here. The Rebel XT flash has an issue of not popping up when the button is pressed. See this page for some discussion and suggestions:
Is the camera otherwise powering up and taking pictures and downloading them? Make sure it is not a battery problem
The display not showing up? If this only occurs in the shooting mode, press the DISP button . Another reason the display shuts down is when you look through the viewfinder- a sensor knows your cheek is next to the screen and shuts off the display. If anything blocks the sensor (located under the viewfinder, the display shuts off.
If the problem also occurs when you are trying to view the pictures (when you press the button with the little triangle) it is more serious and shows there is something wrong with the hardware of the LCD display. In that case consult Canon support.
Jan 05, 2011 | Canon Rebel XT / EOS 350D Digital Camera
'busy' message in view finder won't take a picture
how can you download and update firm ware when you cannot see anything on the screen?!!!!
Apr 07, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon rebel xt 1. image looks blury in eye
1. The viewfinder's diopter is probably out of focus (doesn't affect Auto Focus of photos). There's a dial and a +/- symbol next to the viewfinder. Turn the dial till you can see clearly through it. Alternative reason: The glass in the viewfinder is dirty/foggy. Use camera cleaning solution (a drop) on a cotton bud to clean it.
2. Malfunction needs Canon Service Centre to take a look at.
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera does not fire external flash
Is it in manual or auto modes (camera)Try resetting the camera back to factory defaults as a first step.
Feb 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Nov 23, 2008 | Canon EOS Rebel G 35mm SLR Camera
"busy" in all modes except non-flash setting on 300d
bad memory card most likely.
try reformatting card in camera.
try battery out for 10 seconds for full reset if that does not work.
may have a problem writing to card.
you can also try another card. cf i believe on that camera.
good luck.
Dec 16, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT
It is normal. Camera lightens surrounding to get focus point.
Oct 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
170 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
