Question about Hitachi 50FX18B/19K 50" Rear Projection Television
1996 Hitachi 50FX18B 50"
I have a 1996 Hitachi 50FX18B. RGB colors not synchronized, upper and lower portions of horizontal are in a curve position. please help me find a solution. tnx
  • Hitachi Master
  • 3,459 Answers
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 19, 2009
How do I unlock the setup options for horizontal & vertical adjustments on my 55" HDT 51M 2006 Plasma TV won't let me access the horizontal or vertical options in setup in RGB 1 mode.
You have to enter the service mode option to it, to do horizontal and vertical adjustments. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 25, 2014 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
I have a problem with my hitachi. The picture has vertical blue/yellow stripes. Probably due to a green color split. Can you diagnose my problem?
You probably have a convergence circuit failure. Replacing the Convergence IC's and check for any open resistors for the Blue Sub Yoke located near the Sub Yoke Connector should cure the problem. Most of the IC's are
STK-392-110's, STK-392-120's, or STK-392-150's. Replace them as a set.
Hope this helps,
Skyassoc
Jun 25, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
I have a hitachi 50FX18B and the convergence lines are not aligne
  • Screen looks 3D
Feb 24, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 50fx18b 50" projection no power
Does it chirp? If so you need convergence chips replaced.
Read the link below.
  • Screen looks 3D
  • TV Makes Chirping Sound
Jan 07, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
50 inch rear projection Hitachi looks like your watching in 3d
This is a convergence problem and igf you can solder, you can probably fix this yourself. If you feel comfortable working inside the set, and are aware of the dangers of the high voltage present there. try the following: Resolder the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
Nov 24, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 50fx18b
Press "shift" on remote to write to Rom. "Rom write" is displayed. Press shift again. Wait about 25 seconds, then press "mute" to return to convergence mode.
Mar 02, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 50FX18B
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Spiderwebs under Screen, how do i clean it ?
Yes, I have seen this many times. Usually the best way is to remove the upper back cover and clean out the spider webs with a soft, dry cloth, but be careful because the mirror is mounted to the inside of the cover.
Jun 24, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Distorted view at upper 20% of screen horizontally
Wow for the convergence to shift you must have really moved it. First try the manual convergence on the set. if that dosent help then your gonna need a pro to come in and adjust it for you as it takes special equipment and the know how to do this kind of alighnment as its not a consumer alighnment sorry couldnt assist more. Good Luck
Jun 11, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
156 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
