Question about Magic Chef MCWC30MCG Compact Wine Cooler
Can't figure out how to change the light bulb in my Wine Cooler? Can't get the plastic cover off? help!
  • jdjourneycak Jul 24, 2008
    I tried your suggestion...... I now no longer have to worry about the plastic cover It is now broken But I can now get the light out.... thanks I think!
  • 1,498 Answers
Hello there,
How many techies does it take to change a light bulb (without a hammer)?
There is a tiny screw holding the lens cover in place. Once removed, the lens will come off and you can access the bulb.
Hope this helped
Thanks for using FixYa
Mike
Posted on Jul 24, 2008
    Guru:
  • 1,894 Answers
Press it from both the sides and pull it by applying a little force.
it will come out
How do you change the light bulb in the e wave wine cooler?
I took the screw out but the lens won't budge and I don't want to break it. how does the lens come out?
Oct 07, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Light bulb burned out...........can't find one.cuisinet wine cooler
im a union electrician i would contact a company like graybar electrical supply or granger.com
Sep 12, 2012 | Cuisinart Private Reserve CWC-900 Wine...
The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
Jan 17, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
May 03, 2009 | Haier HVFM20ABB Wine Cooler
Danby wine cooler model dwc172bl thermostat replacement
Once I figured out there were black plastic caps covering the screws holding the inside back panel in place, it was an easy fix. The cooler is now up and running. Thank you for giving me the $10 incentive to figure it out myself.
Jan 18, 2009 | Danby Silhouette DWC512BL Wine Cooler
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Refrigerators
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Aug 30, 2008 | Marvel (6SBARBSG) Wine Cooler
Change light in wine cooler
Took everything out and got on my back with flashlight to find a tiny screw holding lens in place.  Found that a little night light fit and worked fine.  Wish the manual had a simple direction to fix the problem.
Jul 03, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef MCWC30MCG Compact Wine Cooler Logo
287 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
