Question about Goldstar R1003 Air Conditioner
Friedrich air conditioner
New friedrich 28000 btu ac.put through wall. nice tight fit 2 by 6 wall. when on makes a sound like fan is hitting something. all seal gasket's were put on. book calls for 3/8 inch tilt but was given 1/4 inch tilt. is that enough ? don't want water to come into house. don't want to drill hole in pan because i don't think that is good idea. fresh air lever is very hard to move so i leave it in closed. model number is sl28l30 should i send it back because it is so new or let tech look at it first ? what do you think these problems are ? should not have this on a brand new unit. what do you think ? thankyou. Hello,
Not sure if it's an R1003, however, I have had the unit 3 years without problems. It was installed in May and just the other day started making noises like the fan is hitting something (very intermittently). Yesterday, there was a fair amount of water spitting from the unit into the room (only when the fan made noise). Water is draining from the back where it is supposed to. Compressor seems to be ok and unit is cooling. It wasn't anywhere as humid as it has been in the past, however we have had alot of rain in the last week or so.
I really hope you can let me know what is causing this.
Thank you.
  • 143 Answers
I used to be a "Factory Authorized" person, and I bet Friedrich would rather do a warranty call than have you return the machine for a refund. Phone them to see if they are cooperative. When the tech gets there, you can ask ALL your questions and point out every little sticky thing. That's his job!
The tech will be able to get parts and know how to adjust things.
For the second person, you have to look into the space where the fan is hitting something. A mirror and a flashlight will be needed. I kind of get a feeling the water isn't draining fast enough. Look for a plastic tube from the front water pan to the rear water pan. They get plugged up.
Posted on Jul 24, 2008
Friedrich a/c unit keeps flashing ch 34
I have the same issue. My ac is BTU 9800. I was wondering if you figure out the issue ?
Oct 18, 2014 | Friedrich CP12C10 Wall/Window Air...
My 9 year old 17,500 BTU wall mounted window Unit is freezing over with little air coming out. New filter & clean coils still have same problem.
Sounds as though the indoor fan is about to give up the ghost.. 2 choices . 1 start looking for a newer more effecent unit. 2 replace the fan motor.. sorry but it does not sound good..Wiat I just thought It just might have a run capasitor ?? Not sure.. But it could be going bad as well .. Justa thought on that one. either way you can call a tech or buy a new unit.
Aug 08, 2011 | Friedrich Heating & Cooling
Just installed a new Friedrich CP06C10 window air conditioner that I purchased from J&R. Turned it on and it makes a loud rattling sound. I installed a Friedrich CP08C10 window air conditioner in...
its the fan hitting the shroud, look inside for the fan hitting anything and check for the copper lines vibrating against each other, also, it could be the plastic front vibrating, put your hand on the front to see if you can stop it,
Apr 17, 2011 | Friedrich CP06C10 Wall/Window Air...
Friedrich KStar KQ06J10 Air Conditioner not Cooling?
mcdevito75 here, Put the fan on and wait 3 minutes, NOW turn to low cool and place temp to 0 degrees or 1/2 thru the blue section of the cooling knob. Unit should work fine. type in online the unit name plus.com for any other assistance manuals, etc.
Jun 22, 2010 | Heating & Cooling
Friedrich Wallmaster is not throwing cold air.
I have the same problem - bought mine 4-5 years ago been suffering ever since - spent so much money on Friedrich and still using fans. Piece of ****.
Aug 21, 2009 | Friedrich M18CF Split System Air...
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Dear cmr 1,
As you have mentioned that it look like the fan hitting something, this is possible. This kind of problem can occur while transporting the machine. Some times the fan becomes loose because of viberation. So the fan has to be realign. Regarding the tilt it is okay to have 1/4 inch tilt backwards. Since the air-conditioner is brand new it is advisable to contact the company.
regards,
ramesh22
Jun 25, 2008 | Friedrich QuietMaster Deluxe RS12L10 Air...
Goldstar R1003 Air Conditioner Logo
123 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
