Question about Ecoquest Flair Air Purifier
Flair I just received a flair air purifier from my sister and it needs some parts. It is missing the two glass filters and the back filter, could you help me get the wonderful machine operational. ACB
You need to order two ceramic plates and a lint filter. The lint filter is the one that goes on the back. The two glass plates are what ionizes the air. They do not make them from glass anymore. You will need to go to the ecoquest website nd order the parts. It will run you right about $75. Ecoquest bought Flair out a few years ago. Hope it helps.
Posted on Oct 09, 2008
I have a Flair air puifier but no ozone smell. I replaced the high voltage transformer( it was a 3500 watt instead of a 5000 watt transformer) The red light now flickers but no ozone smell . It has ne
Your ozone generator may have gone bad. It's the small black rectangular looking apparatus located near the bottom of the unit. It usually has a zip tie holding it to the circuit board. You will have to take the Flair out of it's case to see it. Make sure it's unplugged and remove the bolt from the bottom of the unit. You can then slide the framework out of the casing. It's also possible that it's time to replace your Ceramic Ozone Plates. They have a life expectancy of 2 to 4 years. The Flair has two of them that slide into slots in the rear of the unit. You can see them when you remove the washable filter. All items can be purchased on Ebay. DM
Apr 28, 2012 | Ecoquest Flair Air Purifier
My flair unit does not smell of ozone. Why ??
It properly needs the filter and interior cleaned. Especially, if it has run a long time without being cleaned. Or there is nothing in the household air at this time to trip the Ozone producing switch.
Feb 06, 2011 | Ecoquest Flair Air Purifier
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
E-mail to and they will help you get a new filter.
Dec 20, 2009 | Ecoquest Flair Air Purifier
How do I clean the metal screen? Do I need to replace any filters at any point?
if the metal screen is removable, run under warm water and gently brush with damp rag
if no removable, unplug unit, wipe clean with damp rag
May 29, 2009 | Ecoquest Flair Air Purifier
Only one plate inside, it's glass edges are broken or deteriorate
I haven't seen an older Flair that I know of. There will be as many slots for plates as are required. The filter is definitely washable. Use an enzyme cleaner and rinse with hot water. The fan motor should be oiled every month or two. It should cost less than $100 to get it running in top shape.
Feb 08, 2009 | Ecoquest Flair Air Purifier
Hi Teresa,
that is certainly not the smell the machine should produce :)
The smells, other then fresh air, might be 'trapped' in the filter. So washing the filter (top rack of the dishwasher works for the metal mesh filters) might do the trick.
Another trick you can try is to put the purifier on the floor, turn it on high mode (away mode) and put a box over it. Let it run for an hour or two and the smells should be gone.
Make sure you have fairly new plates, to make the machine more effective.
Jan 11, 2009 | Ecoquest Flair Air Purifier
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
192 people viewed this question
Top Ecoquest Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
