Old technics sl-eh60
Hi i havent used it for ages and just connected it all up and f61 is coming up then going off but there is basic power in the stereo but it turns off. am not a technical person and am baffled it was working before i unplugged it time ago. many thanks
    Problem Solver:
  • 30 Answers
Bad / old wore out parts in the power supply. Some parts actually need an electrical flow throgh them to maintain stability. If there is no power through some parts like capacitors they tend to go bad. More then likely bad caps.
Posted on Aug 01, 2008
Hi Frank,
Changers and Mega loaders are often with problems once they age. That is why it is a good idea to have a Technician who can work on these at bay when things go wrong. It can be a bad belt, dead motor spot or even a jammed part of the mechanism. I have unjammed many a plastic mechanism and they warp and go out of position which is why I use only single players.
Dec 21, 2012 | Technics SL-MC7 110-Disc CD Changer
My technics hi-fi separates sL-EH790 is not coming on just saying f61 then going off
Hi Shelly,
"F61" is an error code for short and/or overload detected by the processor upon self check.
First thing you have to try to eliminate this kind of symptoms is by disconnecting all of the inputs and speakers connected from the unit then turn it on without them. Let me know if the symptoms still persist...
Jdvillanueva
Oct 22, 2011 | Technics Audio Players & Recorders
Technics tuner amplifier sa-eh750 makes crunching noise and f61 comes up on desplay
I want to change the language on technics hi fi sa/eh750 to english
Jan 30, 2010 | Technics SA-EX500 Receiver
I have an old model PANASONIC SL-CH750E/K It is not playing any of my burned cd's. I have used wmp and nero-7 it simply doesn't recognise them.
A lot of the older cd players just don't play burned CD's due to the newer formatting. You might try copying them in .wav file format, the old units and CD's used this instead of mp3. Make sure the CD's are finalized, but it is probably due to the age of the unnit.
Sep 07, 2009 | Technics Audio Players & Recorders
SL-BD22 SETUP
go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
May 20, 2009 | Technics SL-BD22 Turntable
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Mar 25, 2008 | Technics SL-1200MK2 Turntable
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
635 people viewed this question
 Grubhead
Grubhead
