Question about Acer TravelMate 2300 Notebook
Speed increase sir, i am worried about my acer laptop speed. my laptop has a 256mb RAM, is it enough to get good speed? for opening each page it takes 5 to 10 minutes . sir what will b the problem and how to increase the speed?
  • 40 Answers
FIRST OF ALL GO TO RUN AND TYPE MSCONFIG UNDER STARTUP TAB DESELECT ALL THE SELECTED ITEMS CLICK OK AND RESTART UR PC THIS WILL MAKE A DIFFERENCE IN UR SYSTEM SPEED.
IF UR FACING THIS PROBLEM WHILE WORKING ON BATT MODE SELECT UR POWER SCHEME AS PERFORMENCE
MAIL ME UR RESPONSE @ vishwas_4u@rediffmail.com
Posted on Jul 26, 2008
  • 44 Answers
1st chk other process are running when system startup by pressing
ctrl+alt+del then select task manager.if any unwanted running end it.
then chk u r system speed &tell me
Posted on Jul 24, 2008
Is my graphics card soldered and can I add more RAM?
Laptops are not very easy to upgrade as they are compact computers.
But I have looked a bit on your laptop and have found that the maximum ram that this laptop can have is 8GB which is very good.
I cannot give you further information for now as the Acer web page will not load.
I will keep you posted but you could do some searching on the Acer website.
Thanks.
Oct 20, 2012 | Acer Aspire 5349-2592 Laptop Celeron...
The panasonicCF-73 tough book I am using has 256 RAM, can I increase this to 1gb or 2gb? Thank you,
According to: http://www.upgradecomputermemory.com/ram.cfm/memory/P/Panasonic/Toughbook-Series/Toughbook-73-CF-73
your CF-73 has "integrated" 256MB of memory, and supports a maximum addition of 1GB of RAM.
The web-site says about $33, which _definitely_ is a good investment to speed-up your computer.
Jan 23, 2011 | Panasonic Toughbook CF-73 Notebook
How do i install a memory ram on my computer acer 5050
I don't know your model laptop, but most laptops have one or two memory slots on the bottom of the laptop behind a panel. Remove the panel to reveal the RAM slot/s.
When installing RAM, say 1Gb when there is two 256Mb RAM modules, then you need to replace the existing RAM with two 512Mb RAM modules. Make sure the new RAM is the same speed as the original RAM or faster RAM.
Oct 16, 2010 | Acer Aspire 5050-3242 Notebook
Dear Sir/Madam, i am using ASUS F-80Q laptop and the graphics is GMA x4500hd Gfx, it only shared 256mb memory, but i have seen about 1gb memory can this chip share (in fujitsu laptop)... there is no...
A BIOS firmware upgrade may allow the video RAM to be increased from 256Mb of RAM. Check the motherboard manufacturer's WEB site to see if this is possible.
Oct 06, 2009 | Asrock P4I45GV R5 Motherboard
Ei systems laptop memory upgrade?????!!!
1gb ram will speed up your access memory you will notice it a little faster when going from web site to web site but to really speed it up you need a faster prossesor or / and better broadband
Apr 01, 2009 | Computers & Internet
Acer aspire rejecting memory at 2gb
so u have three chips am i right 1gb+1gb+256mb
basically its RAM compatibility issue check the ram specs is it ddr 2 with the specs that suits ur system or not
if u put 1 gb and 1gb it gives u issues then kindly check the DDR2 PC???? check is it 2100 4200 or 5300 what is ur orig ram rating try the same rating and then check pls also check the bus speed is it 533mhz or 667 or 800mhz
pls only use the compatible ram with ur laptop kingston are good with acer bcoz originally it comes with hynix chip and kingston chips nomally and sometimes samsung chips let me know about the detailed specs of all chips with all digits written on them
pls rate me fixya if ur problem is solved
Mar 04, 2009 | Acer Computers & Internet
Increase the RAM with out fixing any ram cards
In Vista, just connect a flash drive and it will ask it should open it or start ReadyBoost. Choose the latter one and choose how much part of it should be used as memory. But to enjoy it full-time, you need to have it connected always. It is generally used when the PC is freezing a lot and you are running a number of things.
XP is not built to do this, but it can still work. See this video. If it doesn't work, try this international site. But this may take a longer time to load on a slow connection.
Dec 13, 2008 | Lenovo 256MB ATI X1600 Pro VGA DVI-I...
About ram
Yes you're right that increasing the RAM of your computer will definitely increase the speed of your computer and that will make everything fast there and you can open multiple application and still computer is working fast...
Don't forget to rate the solution FIXYA thank you....
Oct 17, 2008 | Computers & Internet
Upgrade for acer aspire 4315
Hi, best and fastest way to increase your laptop speed is upgrading RAM to 4 Gigs, using 2x2Gb RAM modules like this one (UK seller).
Adding a bigger hard drive won't increase laptop speed, but will give you more space to store your files.
Another way to speed up a computer is using CPU overclocking, but this operation, good on old computers, is not worth on a computer with new CPU like yours.
On you tube also some user posted videos on how to upgrade chips on motherboard of old Acer aspire, but I suggest not trying this, as risk to destroy laptop is very high, and it is generally not worth.
Better to stick with traditional upgrades.
Aug 09, 2008 | Computers & Internet
My First RAM Upgrade-Any Tips
Make sure you remove the battery before removing or inserting the ram :)
No worries about it not being dual channel as most laptop arent.
DDr (double data rate) ram runs at 200MHz but is actually 400 one the double data rate is applied so they are one and the same :)
I hope its a sodimm stick of ram that you bought? They are about 3i inches long rather than 6 like desktop ram?
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
