Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Assigning an IP address to a computer
How do I "assign an IP address to a computer" as instructed to access the DLink setup page?
Thank you, susan
  • 298 Answers
If you comptuer is runnin on winxp you can try the steps on this link. click here.
Posted on Jul 25, 2008
I have a dlink router of model DI-1750, i have to configure DHCP..can anyone help me regarding the configuration commands.
A DHCP Reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. You can use these reservations for DHCP-enabled devices like print and file servers or other application servers which always have the fixed IP address on a network.
To configure a DHCP reservation, follow the steps provided below:
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click Setup > Basic Setup.
Step 3:
Make sure that the DHCP Server option is Enabled. Click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Step 4:
When you click on DHCP Reservation, a new web browser window will pop-up. Click the Select checkbox to reserve a client's IP address. Click the Add Clients button afterwards.
kb17362-003_en.png Step 5:
If you want to manually assign an IP address, enter the client's host name in the Enter Client Name field. You can do this as well in the IP Address and MAC address fields.
Step 6:
Click the Add button.
Step 7:
A list of DHCP clients and their fixed local IP addresses will be displayed at the bottom of the screen. If you want to remove a client from this list, click the Remove button.
On this window, you can do any of the following:
• Click the kb17362-006_en.png button to save your changes.
• Click the kb17362-007_en.png button to cancel your changes.
• To view the most up-to-date information, click the kb17362-008_en.png button.
• To exit this screen, click the kb17362-009_en.png button.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | D-Link Computers & Internet
I have a netgear wireless router with WPA security. and i bought a WRE54G . I cannot configure the expander as you know netgear IP is 192.168.0.1 and lynksys expander is 192.168.1.240. when i open...
Try to reset WRE54G
Resetting the Range Expander to Factory Default
The range expander can be set to factory default by pressing the Reset button of the range expander for 20 seconds.
NOTE: The default IP address of a range expander is 192.168.1.240.
After resetting the range expander to factory default and you're still unable to access the web-based setup page, make sure that your computer's proxy settings are disabled. For instructions, click here. To disable the proxy settings using a Mac computer, click here.
NOTE: If all the steps above failed, try to disable any security software on your computer before accessing the range expander's web-based setup page. Click here to learn how to disable your computer's firewall.
If you are using a Wireless-G Range Expander (WRE54G v2 or v3) and you can't access the web-based setup page, perform the following steps:
Checking Physical Connections
Make sure that the computer is connected to the range expander's LAN or Ethernet Port. If the range expander is properly connected, check the LEDs on the network adapter. For instructions, follow the steps below:
Checking LEDs on the Network Adapter
Make sure that the LED light of the computer's network adapter is lit or blinking. After checking the LEDs on the network adapter, assign the computer a static IP address.
NOTE: If the network adapter's LED is not lit, try using a different cable to further isolate the problem..
Assigning the Computer a Static IP Address
For instructions on how to assign a static IP address on your computer, click here. After assigning a static IP address, check the computer's connectivity to the range expander.
Checking the Computer's Connectivity to the Range Expander
For instructions on how to check the connectivity of your computer to the range expander, click here. If you're still experiencing difficulty accessing the web-based setup page, reset the range expander.
For instructions on how to restore the range expander to factory default, click here.
If you're still having difficulty accessing the web-based setup page, make sure that your browser's proxy settings are disabled.
If you're using a Wireless-G Range Expander (WRE54G v1), you need to do the following:
For instructions on how to assign a static IP address on the computers' wireless network connection, click here.
Connecting Wirelessly to your Range Expander
NOTE: In this example we used WUSB54GS V1.0 (Wireless-G USB Network Adapter).
If you're using a Mac computer, click here for instructions on how to connect to a wireless network using the AirPort card.
Step 1:
Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen.
4146-005.pngStep 2:
Click Site Survey then select the SSID of your wireless range expander and click Connect.
NOTE: The default SSID of the range expander is in this format linksysRxxxxxx.
4146-007.pngChecking the Computer's Connectivity to the Range Expander
NOTE: If you're using Windows 98 or Windows ME, click here.
If you're using a Mac computer, click here.
Windows 2000/XP
Step 1:
Click Start, then click Run.
Step 2:
When the Run window appears, in the Open field type "cmd", then click OK.
3984-003.pngStep 3:
When the MS DOS Prompt appears, type "ping 192.168.1.240" then press [Enter].
Step 4:
See if you're getting 4 replies, Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Nov 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
Can't connet to setup page
Sounds to me that you dont have a router, you have a hub. If its a real router it would be assigning IP addresses to each computer. Sounds as if you are assigned the same IP to each computer (possibly). Make sure you have your computer set to dynamic IP not static. Instructions here. Other possible issue is the router is set not to manage IP in that case you need to access the router and change it to manage IP. To figure this out Google the make and model of your router to find manual.
Just to verify its an IP issue, turn off the computer that has access and reboot the other one and see if the one your rebooted gets a connection then. If so its a IP issue, if not check the cable connection and drivers for the NIC.
Mar 26, 2009 | Computers & Internet
D Link model 2310
When you connected your PC directly to the modem, were you able to get the internet working automatically or did you have to run a dialup-like connection?
If it worked automatically, try this:
1. Connect a PC to a numbered port of the Dlink router (don't connect the modem to the router nor the PC)
2. Open Internet Explorer and enter http://192.168.0.1 on the address bar. This should then ask you to login. (restart the router and the PC if nothing happened then try again)
3. Enter admin for the username and blank for the password
4. Once you're on the Dlink Setup page, click on Network Settings on the left panel.
5. Change the Router IP address to 192.168.2.1 then hit Save Settings
6. Now, connect a cable from the Speedstream modem to the WAN port of the Dlink router then check if your internet is working from the wired PC.
If its still not working, turn off the modem and the router and then power the modem first (wait for the lights to be stable) then plug the router.
Hope this works for you. Goodluck!
Nov 07, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
WEP KEY
disabling WEP security is not a great idea, unless you plan on replacing it with WPA. As for your request, please open a Browser and enter 182.168.1.1 into your address bar and hit enter. I can't seem to recall exactly where the setting is, but you will come across it if you look through the router admin page. Hope this helps.
Dec 21, 2007 | Computers & Internet
Unable to access Internet, WAN IP Address present
First you will need to open up your internet browser (Internet Explorer/Netscape) and go to http://192.168.1.1. You will be prompted for a username and password. By default there is no username and the password is admin. Once you arrive at the routers setup page click on the Advanced tab. Once the page finishes loading, you'll find you will be on the "Filters" tab. Look down and make sure that there are no numbers other than 0 in the boxes on that page. If there are, then you will need to replace them with 0's and click Apply, then Continue. Once you've done that, you're going to want to look for Dynamic Routing at the top, and then click on it. Once that page finishes loading, make sure that the "Working Mode" is set to Gateway, not ?Router?, and that tx and rx are set to Disable not RIP-1 or RIP-2. If a static IP address has been set on the computer, verify the gateways matches the Router's LAN IP Address. If there aren't any installed gateways, add the Router's LAN IP Address. When setting static IP Addresses, you must also input the DNS servers. For more information on assigning static IP addresses, please see the related article on assigning static IP addresses. If you?re still having difficulties, please contact Linksys Product Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL and Voice...
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Feb 16, 2006 | Linksys WRT55AG Router
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
