Question about Bosch HMT8625GB Microwave Oven
Bosch Microwave HMT8625 range - Microwave not working
The microwave controls and mechanisms - door, timer, turn-table, etc. all work fine - but the microwave is not heating the food at all
    President:
  • 670 Answers
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Posted on Dec 24, 2009
Frigidaire microwave fmv156dcc
You likely have a failed bottom door switch, or that switch's mount is loose, misaligned, or broken.
The service manual will help you with disassembly, etc. It is here.
My help file on door switches is here.
Jan 07, 2014 | Microwave Ovens
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
Jan 15, 2009 | Emerson MW8108P Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Over range microwave not working properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 15, 2007 | Whirlpool MH6150XL Microwave Oven
Repairing Microwave
check high volatage circuit, and magnetron, and wiring and control unit or circuit...
Oct 02, 2007 | GE JE1540 Microwave Oven
Bosch HMT8625GB Microwave Oven Logo
780 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
