Question about Amana Refrigerators
How to remove a sliding door - Amana Refrigerators
  • 833 Answers
Usually, you can push the door into the track and then lift and tilt.
Posted on Jul 24, 2008
Sliding glass door removal
How to remove a one way sliding door of a curio?
Jan 04, 2014 | Pulaski Furniture Pulaski 20661 Two Way...
How to remove the sliding door
Push up on the sliding cabinet door to release the bottom of the door from the track. Pull the door out and away from the bottom track and pull it down to remove it from the cabinet.-----------------------------------------------------------------------------
Renault CAN Clip Diagnostic Interface
Dec 05, 2012 | 2002 Mazda MPV
Dryer making scraping sound when running
the door slides are worn out on the front door bearing,remove 4 screws from control panel,then remove 2 screws inside toop facing down from the top door area remove front panel carefully so as to not break door switch wires,now you can see the top door bearing and 4 slides 2 white and 2 green slides replace all slides and door bearing itself if worn thru the slides
May 06, 2012 | General Electric DBSR463EGWW Dryer
How to dismantle panasonic sc-hc3 sliding door?
Remove the speaker covers by sliding a screwdriver carefully under the edges and push it up. They are just pressed into holes. Once removed, you have to remove the 4 screws of the top cover (the one with the buttons). After removing the screws slide a screwdriver carefully under the top cover and push it up. Attention, the cover is connected to the body with little cables so do not break them. Once pushed up , you see little screws that hold the top sliding rail. Remove them and you can take the sliding door off. Good luck
Jan 16, 2012 | Panasonic Audio Players & Recorders
How do i change my driver side door my van is a 1994 plymouth voyager
first you go to local book store or dealer or ebay and pick up a chilton or haynes book it will come in handy for the wiring and the hinge torque and allinment specs and tricks
Jan 23, 2010 | 1994 Plymouth Voyager
Handle broke off sliding door on drivers side 2000 mercury villag
Trim Panel —Sliding Door
Special Tool(s) syv~us~en~file=st1181a.gif~gen~ref.gif Safety Belt Bolt Bit (Used for T-50 Head Bolt)
501-010 (T77L-2100-A) Removal
  1. Remove the sliding door trim panel finish panel.
  1. Remove the sliding door trim panel.
Apr 13, 2009 | 2000 Mercury Villager
Broken door handle - 2001 Nissan Quest SE
first you van order parts at discount from
quest & mecrury villager are the same vehicle made at the same assembly plant. good luck to all. If you were in detroit area, I wold help you.
Trim Panel —Sliding Door Removal
532ac84.gif 2. Remove the sliding door trim panel 2965fbe.gif Latch Remote Control —Sliding Door Removal
  1. Remove the rear sliding door trim panel. For additional information, refer to Section 501-05 .
  1. Position the watershield aside.
  1. If equipped, disconnect the sliding door power door lock actuator electrical connector.
  1. NOTE: Mark the position of the sliding door rear latch cable adjusting bracket before removing the bolt.
  2. Disconnect the sliding door rear latch cable.
  3. Remove the bolt.
  4. Remove the sliding door rear latch cable adjusting bracket from the latch remote control.
  5. Disconnect the sliding door rear latch cable from the latch remote control.
  1. Remove the 4 sliding door front latch bolts.
NOTE: If necessary, transfer parts to the new sliding door latch remote control.
Remove the sliding door latch remote control.
  1. Remove the bolts.
  1. Remove the sliding door latch remote control.
Handle —Exterior, Sliding Door Removal
  1. Remove the sliding door latch remote control. For additional information, refer to Latch Remote Control—Sliding Door .
  1. Remove the sliding door exterior handle.
    1. Remove the nuts.
Mar 08, 2009 | 2001 Nissan Quest
Broken exterior door handle,passenger sider ,sliding
Got this idea from Get some stainless or aluminum sheet metal screws, drill pilot hole into the handle and into the receiving part behind, then screw in the screw. Do on both sides of handle (get appropriate length screw.) When done, get some putty or hardener to fill in the screw slot, let dry, then sand smooth, then paint with body color. Result is great and inexpensive.
Jan 26, 2009 | 2004 Mazda MPV
Glass on sliding door
this is the link to the information
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
