Question about Belkin (F5D7231-4) Wireless Router
How can i put a password on my wireless router?
Need to put password
so type in your password to access it
Jun 03, 2015 | Cisco Linksys Wireless N Home Router...
How to put password to wifi?
You cannot a put a password to the wireless card, but you can put a password for the wireless router/modem... You need to login into the router's interface and you need to configure the router by enabling the security.
May 23, 2011 | Encore ENLWI-N3 Wireless N 150 Desktop PCI...
How can I put password on my wireless router ?
Do you mean that you need to put a Password for the "Wireless Network"? i.e. network key or password to access to your wireless connection.
Access to your router, Click on "Home" then click "General Setup" icon, then you click on the "Wireless icon" check on "Security Settings" and set your "Encryption Key" (There are 4 Encryption Keys, setting one will do.
Hope it helps.
Apr 24, 2011 | Edimax BR-6226n nLite Wireless Broadband...
My internet connection via the router (d-link DI-524) have slowed down. how do i reset settings or put a password?
Maybe you have an open WiFi (no password wireless) and anyboby near can connect to your router and download files, this can slow down your Internet connection. To put a password to your wireless network, enter setup preferably by a wired connection to router, in your browser type the default IP address of it (http://192.168.0.1), the user is admin and its password must be left blank (default settings), at the Home tab go directly to Wireless option since you'll only change your WiFi from unsecure to secure, there you can choose the security type, WPA is recommended, after select it you can put the new Key (password) of your WiFi, and finally apply to get changes working, just remember that after this procedure, you'll have to enter the password in each new wireless connection to your router.
Feb 21, 2011 | D-Link AirPlus DI-524 Wireless Router
Router password
>If you're trying to put password for the Router, then type "http://192.168.0.1" into the address bar, then hit "Enter."
>Use "Admin" as the username and leave the password blank when the login screen appears.
>Please click on Administrator settings and change the User Name and Password.
If you're trying to put a password/secure the Wireless network, then follow the steps:
>In the Router setup page, click on Wireless Settings.
>Under Wireless Security Mode, select Security Mode: WEP/WPA/WPA2.
>Enter the Security Key manually or enter the Phrase to generate the Security key automatically (only in WPA/WPA2) and save the settings.
>Please note the Security Key to connect to the Wireless Networ.
>The Wireless is secured now.
Good Luck!!!!
Jul 02, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How to put password?
Hi Friend,
Please follow the steps in order to secure your network
1.Open router page (192.168.1.1)
2.Enter the username and password (default password is admin and leave the username blank)
3.On the router page click Wireless and fill the sections as mentioned
Wireless Network Mode-Mixed
Wireless Network Name-As per your choice
Wireless channel-6-2.437Ghz
Wireless SSID broadcast-Enable and click save settings
4.Click Wireles Settings and select the Security Mode as WEP
WEP encryption-64 bits 10hex digits
Key1-Enter 10 digit or 10 letter password(like your telephone number) and click save settings.
Turn off the router for 30 seconds and turn it on after that. Your network is now password protected.
I hope this will resolve the issue.
Regards
Chiranjeet
May 19, 2010 | Linksys Wireless-G Broadband Router
How to put password to router
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i put a password on a wireless router
- Find the address of your router in the router's manual.
- Go there and login using the default username & password (also in the manual)
- Once logged in, there is an option to change the password as well as the wireless encryption key (wireless password)
Oct 08, 2009 | Cnet CWR-854 Router
I've just added a password to stop hackers on my D-link wireless. How do I activate it?
What do you mean by you put a password on it. You put a password on the router on a key in the actual wireless settings? If you hit apply then it will save it and then you just log into the router with your wireless connection using that key. you can test it by trying to connect with the wrong key/password. Hope this helps.
thanks,
Lee
Sep 15, 2009 | D-Link AirPlus DI-524 Wireless Router
I want to put a password to my wireless network
you will have to use one of the encryption supported by wifi..
try enabling WEP on your wifi router....
Jan 26, 2009 | Zonet ZSR1104WE Wireless Router
Belkin (F5D7231-4) Wireless Router Logo
73 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
