Question about Cobra 29 LTD CB Radio
With the engine of the tractor running the cb squeels when i key up and does not squeel when the engine is not running. i have established a new ground also a new antenna thinking that would help but no luck
Try checking your dynamike, might be too high. causing feedback
Posted on Aug 05, 2008
2002 highlander--started squeeling from the belt area in Feb. Had belt replaced, was worn. It would squeel on starting then stop. Now turning on a/c makes it squeel. Fan works and after a little while
try cleaning the cogs that the belt runs around some times the belt puts a layer of rubber on them when the belt slips which makes the new belt slip if not could be a bearing in the pullys the belt runs around
Aug 14, 2012 | 2002 Toyota Highlander
2547 when turn on has a squeel thru the speaker in recieve mode
hi iff you remove the mic does this squeel disapear ,if so i recomend that you open mic casing and check for any lose strands of wire that could be shortening out ive seen this happen so many times with microphones you can get some switch oil and apply sparingly to switch this will also help in the long run ,,,,,goodluck with it
Feb 11, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Radio squeal.
Check it with the external speaker unpluged, turn the mike gain down a little at a time, until it does not squeel. ..hope this helps..
Mar 20, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
My grant has good mod on sideband but when i transmit on am i get a squeel like sound coming in with my voice but the squeel is louder then my voice. could it be a bad shield on my hand held astic power...
If you have talk back, that most likely why you have feed back. If its on a switch, turn it off. When it was put in, it was done too loud. You can also turn down the gain on the mic.
Dec 21, 2009 | Uniden GRANTLT 40-Channels Base CB Radio
Squeeling when the car starts.
Your belts need replaced. Its the belt slipping that causes the squeel. Sometimes the idle pulley or belt tensioner will make the same noise if wore.
Mar 22, 2009 | 1993 Mitsubishi Eclipse
RCI 2970 squeels until you unplug the external speaker and plug i
Strange! I used to run almost the same kinda setup but with a super scanner omnibeam, i modded mine myself. At 1 time i had a squeal problem it was in the mic if i remember correctlly i ran a external wire from the screw on the spring inside the mic where the cord comes out to the radio chassis and it stopped it give it a try. I used a simple speaker wire, also you might want to try grounding the radio to the power supply. Sounds like a ground problem! I have a awsome mod for that radio that would enable you to run a regular amp with it and also would enable you to talk local without engaging the amp in the radio using only 4 watts! Let me know how it works out for you with the squeal? if intrested in that mod contact via email at (noteethontop@yahoo.com). put 2970 in the subject line. Take care.
Jan 17, 2009 | Radio Communications
Engine noise on area of pulleys and sometimes engine tries to sto
Don't know if this helps. Had squeel in belt area. Occasionally engine would stop when squeel got loud and sometimes engine would try to quit while going at various speeds. Found tensioner pulley was bad and changed it. Still squeeled and engine would stop when squeel got loud. This time while sitting in yard. Further checking found binding in power steering pump. Will be putting on new one tomorrow. Hope it works. Will update.
Nov 28, 2008 | 2004 Ford Freestar
Cobra 29 LTD CB Radio Logo
104 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
