Question about Refrigerators
Whirlpool frig model -et9fttxlq11 serial-9m5110756 inside at very back water comes out of this opening
  • marymeaders Apr 17, 2009
    I ha water in the bottom of my refrigerator under the vegetable bin. What can I do?
  • 525 Answers
Your issue is;
"whirlpool frig. model -et9fttxlq11,serial-9m5110756
inside at very back water comes out of this opening"
Thank you for providing a valid model number!
This link shows exploded view of your model.
http://www.repairclinic.com/0100_2.asp
Water can leak from these areas:
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
    The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
    The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
    Please show your appreciation by rating my solution.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Posted on Jul 24, 2008
    I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
    Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
    Oct 27, 2014 | Whirlpool Refrigerators
    I need to replace the interior water line on my Whirpool Frig. I had stored the frig in a very hot trailer for 2 weeks. It seems that the poly Eth water line inside the frig and developed mold. I removed...
    Hello Phillip! We are terribly sorry to hear of your concern with your Whirlpool Refrigerator. We would recommend the use a Local Certified Technician in your area to properly replace that water line. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name,user id (Phillip), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We look forward to your reply.
    Jun 17, 2017 | Whirlpool GD2SHGX Refrigerator
    I have Whirlpool frig. When it goes into defrost water drip inside the frig and collects at the bottom. The water appears to be coming into the frig through a channell in the center back of the freezer...
    Hi Patrick, Looks like you have a drain hole that is plugged up with ice, there is a easy way to fix it, I will refer you to this video that shows you how to clear the drain. Take care Ryan http://www.youtube.com/watch?v=_ycWz_U_GDU
    May 29, 2011 | Refrigerators
    Whirlpool side by side frig, model #: ED2JHGXRBO2, serial #: ST2854810. We have had this frig for several years and almost from the get go when you open the right side door, the door gets so far and always...
    I own a whirlpool fridge (side by side) model # ed2jhgxrt02. with a problem with the ice maker. the water is not being delivered to the ice makers. it seems that the switch to turn on the water to flow is not making contact. any suggestions?
    Jan 04, 2011 | Whirlpool Refrigerators
    Water at bottome of refrigerator
    Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
    Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
    Whirlpool Refrigerator water leak through Ice dispenser
    You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
    Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Water building up in the main compartment
    this is a plugged drain there may be a small cup up in the back of the fridge you can take out or you have to remove the freezer plate to access the drain
    Apr 29, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
    ICE MAKER NOT MAKING ICE &WATER DISPENSER NOT DISPENSING WATER. WIRLPOOL ET9FTTXLQ11
    Check the water filter cartridge - possibly needs replacement. It should be near the bottom of the unit in the front.
    Mar 28, 2009 | Whirlpool ET9FTTXL Top Freezer...
    Water dripping from somewhere inside the refrigerator
    I believe the problem is with the drain line when the frig goes into defrost mode
    see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
    facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
    take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
    try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
    If you are not able to find it you can call whrlpol customer service 1-800-253-1301
    or call an appliance service enter and as them f they can walk you through the problem
    Good Luck
    Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
    Ice Maker not going through complete cycle
    what kind of unit is it? there are several possibilities
    May 07, 2008 | Refrigerators
    Refrigerators Logo
    324 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
