Question about Motorola Mobility RAZR V3
Razr v3 screen problem
I have seen a lot of posts about screen problems but none like this. If the phone is turned off then back on, not on the charger, the LCD (both internal and external) will not come one. The phone does, howerver. At this point, if I plug it into the charger, turn the phone off, then close the cover, the external LCD will flicker white then come on. At this point, I can open the phone and the internal LCD will function normally. I can then turn the phone on and everything is fine. Of course, once turned off I have to repeat the steps above in order for the phone to function normally.
I don't see how a loose connection could be the problem nor the LCD's themselves. Has anyone else had this problem?
Thanks,
Tim
  • tjfitz68 Jul 25, 2008
    rubyisred,
    No, not yet. I thought of that but given the fact that it will come on on, using the method described above, and stay on until powered off I wouldn't think it to be a loose connection. I suppose it wouldn't hurt to look.
    Thanks
  • Jeanie
    Jeanie May 11, 2010
    have you checked to see if it might be a loose connection between the top and bottom of the **** shell? This needs to be ruled out first. Are you able to remove the 4 screws and check for a loose connection?
My Motorola Razr v3 cell phone's lcd is blank
unscrew it and change the flex to enable it view programms
Jul 17, 2009 | Motorola Mobility RAZR V3
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Screen doesn't work. only after sereval attempts
This is a known problem for Razr V3. I had a phone like it with the same problem four years ago... I bought another brand and put the V3 away..three years later the phone works perfectly but I have not used it since three years..only turned it on to see if the screen will come on. Get the phone repaired or buy a new one. this is common on a RAZR
May 28, 2009 | Motorola Mobility RAZR V3
Keypad acting up!
SURGICAL - you need to replaced the mobile flexcable in the phone also have the repair center flash the keypad flexfile back into the phone.
BRENNA - replaced the flexcable
VGETSON - you need to flash a file call keypad flex into the phone to correct the keypad freezing up on you.
Sep 27, 2008 | Motorola Mobility RAZR V3
Software doesn't want download
the razr v3 has proprietary software there are programs out there for the pc/mac, but none free that i've seen so far . visit modmymoto.com there may be something new by now.
thanks for rateing.
Aug 21, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola razr v3 screen will not appear
take the phone and ahve the flexcable replaced on the phone.
Jul 20, 2008 | Motorola Mobility RAZR V3
Problem with a RAZR V3
sounds like youve just had a short in your screen wiring. go back to where you got the phone and ask for an exchange
May 01, 2008 | Motorola Mobility RAZR V3
Motorola Razr V3
this problem has probably occured due to the phone being knocked. i used to have a motorola l7 slvr and it did exactly the same, i found that if you hit the back of the phone fairly hard the screen would come back on. im not sure if it is the same for the razr but hey its worth a try. ti be honest i think motorola are terrible mobile phone manufacturers but great 2way radio manufacturers
Mar 17, 2008 | Motorola Mobility RAZR V3
Bootloader usb ini
take the phone to a mobile service center and have them reflash the firmware on the phone....to bring it back.
Jan 26, 2008 | Motorola Mobility RAZR V3
Bottom line on Razr V3
First it was very thin phone, extra care needed. If you dont drop or step to that phone your be fine. And just wait for the replacement to come and take care of it.
Aug 04, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
196 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
