Question about Toshiba Tecra A4 Notebook
Keyboard problem The Spacebar doesn't work when you press it, but when the laptop is idle you will see that the mouse cursor, which blinks for us to type our text, will start moving and not stoping as if your hand is pressing on the spacebar key on the Keyboard.
  • 300 Answers
It sounds like you have a space bar that is stuck in the pressed position.
First, I would try cleaning with compressed air. This can be purchased at most any retail store in the electronics department. One you have it, just clean around each key as good as you can.
If that doesn't work, you can try to remove the keyboard so that you may be able to clean it better. Below, I have listed a site with instructions for removing the keyboard and also a site that has cleaning suggestions.
Keyboard removal instruction site:
http://www.trustyourtechnolust.com/?page_id=7
This site also has pictures to help you along.
Keyboard Cleaning suggestion site:
http://www.sunvalleyus.com/ToshibaKeyboard/A4.html
This site list cleaning suggestions under the Product Knowledge section. I would only proceed as far as you feel comfortable in these instructions.
Thanks
Posted on Jul 24, 2008
  • S C Jul 24, 2008
    I forgot to mention, the site that I gave you earlier, http://www.sunvalleyus.com/ToshibaKeyboa... also list a possible replacement at the top. Just make sure that your model, which can be found on the bottom of the laptop usually on a silver sticker, is listed in the Compatible with the following models: section.
    NOTE:
    This is not a recommendation of this product. It is only one of many possible choices available.
    Thanks
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
My cursor on my HP doesn't work. don't want to use a mouse.
i'm sure that there's a button to lock the trackpad,it's near the panel.you need to press it once again to turn the panel on
I think it's right above the trackpad
or look on your laptops keyboard for a picture like trackpad press it with the function Fn button at the same time
or it should be the hardware
the trackpad cable maybe doesn't installed properly,not locked or something
Aug 20, 2012 | Computers & Internet
Spacebar on keyboard makes my computer go to sleep mode
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
Mar 23, 2012 | Compaq Keyboard
Frustrating problem with spacebar causing skip
did you tried to clean the inside of the keyboard coz sometimes the dust is the cause why some characters not working properly.
Sep 16, 2009 | Computers & Internet
Cursor moving erratically
Sounds like your internal mouse maybe be malfunctioning and due to the pressure on the spacebar is causing the erratic movement.
To fix this you can enter your BIOS with the F2 key at startup.
Continue through until you find some input options to disable the internal mouse.
Jan 23, 2009 | Toshiba Tecra M1 PC Laptops
Bluetooth keyboard and mouse not working with computer
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 09, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Pressing spacebar once will make cursor skip 3-5 spaces
I had the same problem on the Logitech MX3200 wireless keyboad. I simply unplugged my receiver from the USB port and plugged it back in. It's not the first time I've had this happen
Jan 07, 2009 | Logitech Cordless Desktop MX3200 Laser...
Toshiba Tecra A4 Notebook Logo
370 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
