Question about Baby Bjorn Active Baby Carrier
Backstrap slid out
While adjusting my back straps, one of the shoulder support straps became unattached to the device in the middle of my back that held the two straps together. It seems as though it could be slid in again somehow, but I cannot figure out how.
There is a recall on this model. The company will send you a new holding device for the back straps that has screws instead. See the babybjorn.com website for more info.
Posted on Jul 25, 2008
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
I took the straps off and can not put them back, can you help?
The Long strap goes under the seat and comes up thru 2 holes (each end goes up thru each side). The holes are on each side of where the child sits. They come up and weave into the latches that snap into the **** clasp. Upward toward where the child's head would be they go thru the chest clasp. Look at the writing on the clasp to make sure it is on right (letters read the name Cosco and arent upside down) and the belts should be behing the clasp (in at the bottom of the clasp and out at the top). Up thru the holes on the back of the chair at the height appropriate for the childs body. Out the back and down to the claw that is on a strap under the front that you can pull to tighten or press to release slack as the child gets bigger. There should be 1 or 2 (usually 2) slots for the ends of the straps to be slid on to. Sit the child in the car seat and adjust the belt system so that a finger can be slid between the belts and the child's shoulders. This should do the trick. Good luck and be safe.
Mar 18, 2011 | Cosco High Back Booster 22-200 /22-207
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
I need to adjust the straps to my car seat to fit my growing baby. I have tried multiple times to thread it through the back, but it will not work! I have tried everything and it seems impossible. Is...
you need to turn the car seat over and on the very bottom there are two gold rectangle-shaped clips holding the straps. You can pop these out and feed them through the hole....not like other car seats where the straps unattach up at the shoulder end.
Nov 01, 2009 | Evenflo Embrace
How can pull adjustment belt
The shoulder straps feedthrough a loop in the adjustment belt so when you pull on the belt it tightens the straps. When you say it came out, if it has come out completely then you will need to remove the car seat and locate where it connects to the shoulder straps before feeding it back through the hole again
Aug 15, 2009 | Maxi-Cosi Baby Gear
Adjusting the shoulder straps on the Maclaren volo stroller
What year is your Volo. Different years adjust differently. The newer ones have 3 height adjustment slots and a slider that adjusts the strap itself. They do not adjust way down though and even with teh straps as tight as they will go, they are still a little loose on my 15 month old granddaughter. I have found that buy tightening the waist straps it does keep her a little more secure.
Mar 15, 2009 | Maclaren Volo Umbrella Stroller
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Jul 31, 2007 | Evenflo Embrace - Rainforest
Shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: http://www.evenflo.com/ Evenflo ParentLink Department: 1-800-233-5921
Mar 31, 2007 | Evenflo Aura Traditions Travel System...
Baby Bjorn Active Baby Carrier Logo
180 people viewed this question
Top Baby Bjorn Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Bjorn Baby Gear Expert? Answer questions, earn points and help others
