Question about Refrigerators
My subzero fridge is not cooling like it should. milk will sour in about 2 days. Im trying to find a list of dealers in the Brewton, Alabama area. Im having a hard time finding someone to do a service call, thanks, Daniel
  • 525 Answers
Your issue is;
"my subzero fridge is not cooling like it should. milk will sour in about 2 days. Im trying to find a list of dealers in the Brewton, Alabama area. Im having a hard time finding someone to do a service call, thanks, Daniel"
Before contacting a servicer, you may want to check on a few simple things first.
1. Are all doors closed and sealed tightly all the way around?
2. Are the cold controls properly set or adjusted high enough?
3. Is the condensor coil clean?
4.Frost build up in freezer on the back wall. This issue would be a defrost cycle problem and may require a technician.
This link should allow you to connect with a local service agency
http://www.magicyellow.com/category/Appliances_Household_Major_Repair/Montgomery_AL.html
This link may also be of some help.
http://www.constructiondeal.com/service/Appliance-Repair.552.html?rid=5&aid=552
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 24, 2008
Milk leaked out into the back seat our truck I didn't know it until it started to smell. Iv'e sprayed nearly a whole bottle of febreze for fabric on it. while it is wet with the spray you can't smell the...
Try baking soda.
Take a box or two of it and sprinkle it all over the area where the milk was.
Leave it for up to week, and be careful to keep it dry.
Later on, you can vacuum up the "dust".
God bless your efforts.
Dec 11, 2017 | Ovens
My freezer is workin but my fridge isnt cooling. food n milk went sour.... whats goin on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Magic Chef CTF1826AR Top Freezer...
I have a Haier HRD-211 HP5 direct cool fridge. Last couple of days the air around the fridge is smelling like spoiled or sour milk - no smell inside or on the body of the refrigerator and cooling is fine...
Check the defrost water evaporator tray located inside the bottom grille. You probably will find a disgusting mess. Remove the tray and scrub it clean to resolve the problem. While you are cleaning up, check the tube that directs defrost water into the tray. It may be clogged.
Jul 02, 2017 | Haier Refrigerators
The refrigerator cools every other day. My food has spoiled. The freezer works find. I need a repairman that makes in house visits. I live in Mobile, Alabama
Do a search for "refrigeration repair Mobile Alabama" this will get you the number of a repair technician in your area..
You might also want to...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not cold enough to hold milk resulting in the milk becoming sour. Fridge temperature is 10 degrees C how can we make it cooler? We have already set the temperature to the dial 7.
You could do the simple things like clean the dust and stuff around the compressor condenser. Check the condenser motor. Good air flow improves performance and cost nothing to fix. Of course if you are experiencing a defrost problem the air from below gets choke out with ice buildup around the evaporator area. If you have frost on the backside of the freezer section changes is you have a broken defrost heater.
Apr 19, 2010 | Whirlpool GB2SHDXP Bottom Freezer...
Subzero does not cool sufficiently, even with cool
yes you have 2 compressor. ona for fridge one for the freezer..
Nov 29, 2009 | Sub-Zero 650/SRH Stainless Steel
I bought a little portable refrigerator for my daughter for college. she says it is turned up on high and still is not colling properly. Milk sours in two -three days. It is a Ge brand and #008469117900...
You will either have a blockage in the system or a leak. The fact that it is partially cooling, it is very possibly a blockage. Unfortunately, a fridge technician is required. Possibly seller of fridge will cover repair cost or at least 1/2 of the cost.
Nov 13, 2009 | GE Refrigerators
Subzero 632/s won't cool also frost build up in fridge
you have a leak in the evapator you will have to call a subzero tech to get it changed..
May 03, 2009 | Sub-Zero 632 / S
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
