Question about Maytag Refrigerators
I need to replace the fresh food door gasket, what is the best way, and i purchased the gasket already and it has a few dent in the oart that is puffy. what do i do about that?
  • 55 Answers
You could try soaking in hot water to heat and soften it up. You could also try a hair dryer. The dents might just pop out.
Posted on Jul 24, 2008
Where can we buy new door seals
Hello;
My name is Peter. I am a retired field service appliance technician.
New door gaskets need to be soaked in hot water for 30 minutes before mounting to allow for forming.
Some door gaskets are a tang and groove and easily installed others have sections of backing plates and about 32 screws to remove and mount.
Door gaskets are expensive.
Go into the following website and put in your model number, which is located on the upper inside wall of your fresh food section. You will see diagrams with part numbers. Copy the part numbers and go into the internet and search best price.
Water Filters Lawn Garden Appliance Parts
May 07, 2015 | Refrigerators
What if refrigerator section isn't cold but freezer side is freezing? It is a side by side Frigidaire.
Hey friend, thank you for your inquiry!
I understand that your Frigidaire refrigerator is not cooling within the fresh food side but cooling in the freezer. I would check to assure that the vent assembly is not blocked by any food, if so remove the food and allow your refrigerator to cool down.
If there is no food blocking the vent place your hand in the fresh food side to see if any air is moving out of the damper. If you do not feel air coming out it could be an issue with your evaporator fan. Additionally we should check to make sure the gaskets are not bad. You can do that by using a dollar bill. Place the bill between the body of the fresh food and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. I hope this information has been helpful. - Matt
Oct 12, 2014 | Frigidaire Refrigerators
Frezzer keeps icein over
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Oct 08, 2014 | General Electric Top Freezer 21.0 Cubic...
Why did I developed a problem with the freezer on my EI23BC36IS3. Ice and snow like conditions have developed, and it is not from the door being left open. I am at a loss on how to correct the probl
Good Morning Leo,
I understand you are having ice and snow like conditions in the freezer of your Electrolux refrigerator, model# EI23BC36IS3. I also see that it is not due to the door being left open. I suggest checking the seal around the door for any type of damage or possibly the door is not sealing correctly. With the heat and humidity, this could cause the frost inside the freezer. Your appliance comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, simultaneously press and hold the Fresh Food up, or plus sign, and Fresh Food down, or minus sign, keys for 5 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, simultaneously press and hold the Fresh Food up, or plus sign, and Fresh Food down, or minus sign, keys for 5 seconds. A "d" and "F" will be displayed until the defrost cycle is complete. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Electrolux Refrigerators
How many cu ft is it? need new seal for door hmg241770 admiral refrig
Not sure what the cubic feet for the doors for that refrig. but i have the part#'s for you
Fresh food gasket 61004010
Freezer door gasket 61004011
hope this is your looking for
Gene
Aug 01, 2011 | Kitchen Ranges
My freezer door pops open everytime i shut my refrigerator door
Good day,
First, make sure the gasket including the bottom is clean, as well as the mating surface of the machine itself.
The machine itself should be checked for being level. Side to side, if it's a top freezer model, the hinge side cannot be lower than the other side.
As well, front to back it should be leveled but with a slight tilt to the rear to assist in closing.
If none of this helps, then the magnets in the gasket itself have gotten weak and the gasket needs replaced.
Notes: Heavier items keeped in the freezer door will help to a degree. Closing the door slower as well.
The reason this happens, is that with the main door open, then closed, a large volume of air is forced into the fresh food compartment. There are vents that are open between the freezer section and fresh food compartment. This large volume of air when closing the main door is compressed into a smaller area, causing the problem.
Feb 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
On our Fridgidaire refrigerator - freezer door comes open
Good day,
When you close the fresh food door, air is pushed in, and forced into the freezer compartment.
Check to see if the machine is leveled. Slight tilt to the rear is ideal.
If the freezer door fits properly, then usually it is weak magnets in the door gasket, and the door gasket needs replaced.
There are specific details on how to replace a gasket. A qualified counter-man at an appliance parts house will explain the details.
Very important.
Nov 09, 2009 | Refrigerators
Dents
Look at the door, is there a bunch of screws holding the magnetic gasket on? They probably hold the whole plastic inside part on, too. If you are real lucky, the insulation inside will come out easy. If it has been sprayed or poured in, you can't get to the metal to pound it flat from the inside out. For that you would need a bunch of groovy car body working tools. It would take all day,,and what are you going to do with the food, a cooler? How about hiding the dents with decor objects, I'm not sure refrigerator magnets will stick. P.S. If you do take the gasket off, tighten the screws only a little while checking the door fit. Once you know it is flat, you can snug them up.
Apr 28, 2009 | Refrigerators
Kenmore 596.50692000 refrigerator. Every time I shut the refrigerator door, the freezer door pop open. What can I do? Do I need to replace the magnetic strip around the door? Who can give me instructions?...
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Let me know if this helps, Thanks, Sea Breeze
Mar 25, 2009 | Kenmore Refrigerators
Fresh food side freezing
the air damper is stuck open or tempature control is bad. look thru the vents(use a mirror) on the left rear(top side) of the fresh food compartment (right hand door) to see if the air damper is open/closed. i am sure it will be open since your freezing food in the ref section. if it is open ,watching with your mirror turn ref (fresh food) control off. the air dmper should close, if not damper could be stuck(ice build up,piece of foam,ect) if you can determine damper door is free, then best thing to do is replace controlassy.(120.00 or so) good luck
Nov 06, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
52 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
