Question about Intel Pentium IV M, 3.06 GHz Pentium 4-M (SL77P) Processor
Quarry if we see the properties of my computer it will show .if the processer is dual core.
  • 3 Answers
See task manager
Posted on Jul 27, 2008
Vibration mode is not working on vibrate Mode as well as Sound Mode on my Samsung GT I8262
hear try or reset all if well done f we not ur hardware of cp is problem
How to Soft Reset or Reboot or Restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
There are several ways to do soft reset or restart, the easy way to soft reset or reboot or restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL by remove the battery and then put again to the place then turn on the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL. If you do not want to open the battery, you can do easily with pressing Power Button for several seconds and the option menu to turn off or reboot will appear.
#Option 1, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with software menu:
  1. Turn on SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  2. Make sure SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL battery is not empty
  3. Go to menu: Setting > Backup and reset > Factory Data Reset > Reset Device
  4. Choose Erase Everything
  5. SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will do the process to Master Reset to Factory Default, wait for several minutes.
#Option 2, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Hardware key button:
  1. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL charge properly
  2. Turn off SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  3. Press and hold together : Volume Up Button + Home Button & continue with Power Button (together)
  4. If we see the menu at LCD screen, choose Wipe Data/Factory Reset with Volume Button to select and use Power Button to ok or enter.
  5. The SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will doing the process of restoring to factory default.
#Option 3, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Secret Key Code Security:
  2. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL not empty
  3. dial or press number to call: *2767*3855#
  4. That number code will force format SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
How to Restore and Reinstall Clean Android Operating system / firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
Do not worry to do reinstall or restore the clean and default setting Android operating system or firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL because the file source already saved inside the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ROM. If we think the phone really need to be reinstall or restore the default Android operating system or firmware, then we can do it easily by doing hard reset or master format step above, because the operating system will be reinstall by itself.
goodluck sir.
Jul 04, 2014 | Samsung Cell Phones
Aopen ux915g
Yes. Any Intel Pentium 4 processor will fit fine. That said A P4 processor is fast, but the Pentium D is much faster. The D stands for Dual Core. This means that they have two on die processor cores instead of just one, as the Pentium 4 does. Two processors also makes it better for "demanding" applications.
The Pentium D is better if you have a motherboard that will utilize the technology. As stated the Pentium D is Duel core. This is Intel's way of creating the closest environment of a true duel processor. The HT is for Hyper-Threading which acts like a zipper and allows several applications to process at the same time. The Pentium D will really make a difference when used with the new 64 bit operating system.
However, HT (Hyper-threading) P4, does have emulated Dual Core processing. In short, the processor makes the computer think its runing a dual core. The Pentium 4 also has a couple different levels, so if you are trying to make a comparison, make sure that you look carefully.
Although neither can match the power of an Athalon or an AMD x2 processor. If you are buying, get something with 64 bit processing. WAY faster and better for games and high graphic systems.
May 13, 2014 | Computers & Internet
Enable hyptreading
Hyper-threading is technology available on some Intel processors. If your process and motherboard are hyper-threading, you can enable to option in your Windows operating system. Hyper-threading allows your processor to perform multiple operations at once. Hyper-threading is used on multi-core processors and will share the workload among each core.
Restart your computer and repeatedly press the "Del" key or the F2 Key to enter BIOS this will vary depending on your computer and BIOS Press "Tab" to highlight "Main" then use the down arrow key to select "Hyper-Threading-Technology" then press "Enter". Select "Enabled" then press "F11" to exit and save changes. Your computer will now restart with hyper-threading enabled. Click "Start" then "Control Panel" and double-click "Device Manager". A window will appear showing your computer's hardware devices. Click the "Processors" drop-down menu. Right click one of your processor cores then click "Properties". Confirm hyper-threading is enabled. Hope this helps.
Jan 01, 2013 | Lenovo IdeaCentre B320 7760-2SU All-In-One...
The clock speed on Windows 7 Ultimate shows only 1.60Ghz
It depends on the processor you have installed. Dual or Quad core processors are slower e.g. a dual core listed as 4GHz is actually 2GHz per core. With laptop processors, if they have Speedstep technology then the speed will vary depending on the processing power required.
Mar 03, 2011 | Computers & Internet
My screen is showing Big Icons How do I shorten my screen.
Hi:
Right mouse click anywhere on the screen, then select properties, or personalize, depending on your version of windows. Next find display properties, and adjust your screen resolution higher, and your icon's will be smaller!
Oct 05, 2010 | Dell Inspiron 530 -Intel® Pentium®...
I want best desktop configuration for using stake broking purpose, please help me
Here is your resolution for your quarry.
I do suggest any of the below PC which is really compatible with any Hardware/Software and really User friendly Systems.
If you still not fine with the below mentioned systems or if you have nay other quarry regarding to nay problem do reply me.
May 31, 2010 | Dell Inspiron 580 Desktop Computer (Intel...
Want to buy a new computer for personel use , which cpu is better dual core or core2duo girish email. girishpratap@yahoo.co.in
If you going to be using intensive programs like 3d editing, gaming, video editing, photoshop/image editing, or just multitasking and keeping alot of programs open you should get a faster cpu speed, and probably the core 2 duo. Core 2 duo (intel) is dual core and 64bit which gives more processing power, for some applications. Dual core is just normal processor (32bit) and just has 2 cores.
CPU is basically for the computers thinking/multitasking/processing info. If you want to multitask alot of programs your going to need processing power AND alot of RAM, the more the better/faster. If your going to be gaming or doing intesive stuff with graphics, you need a powerful video card. And hard disk is solely dependent on your storage needs too.
If your just going to be surfing the web, emailing, facebook, watching dvd's, and whatnot, any computer (new) should do you fine. But if you want HD video you need a powerful video card and processor.
Also When I mean powerful I dont mean the most powerful, just the mid-range of 'power'. So if you want to get anything more than basic, go for a mid-priced PC. Also this will let your computer last longer as updates and new software tend to slow down your computer, and you need more power to keep up with new stuff, but don't worry, it wont happen that fast!
Feb 27, 2009 | Intel Core T2300, 1.66 GHz Core Duo...
You given me computer chip
A computer chip is a small electronic circuit, also known as an integrated circuit, which is one of the basic components of most kinds of electronic devices, especially computers. Computer chips are small and are made of semiconductors that is usually composed of silicon, on which several tiny components including transistors are embedded and used to transmit electronic data signals. They became popular in the latter half of the 20th century because of their small size, low cost, high performance and ease to produce.
Dec 23, 2008 | Dell A215 Computer Speakers
DVD Writers can read but can not write
update their drivers: they're indicating readers, not writer devices..
Mar 25, 2017 | LG GMA-4082N DVD±RW Burner
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
