Back to:
Tags:
SanDisk 2GB Cruzer Micro USB Flash Drive  Hard Drive
Scandisk 4.0 cruzer
posted by jcruz190 on Jul 24, 2008
My scan disk was working two days ago but it is no longer working. Most of the time when I plug it in it flashes once and stops. There have been occassions that when I plug in the drive it stays on but the computer does not read it.
My email address jcruz@dkdr.com, please help....
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 28, 2008
Not Rated (0)
anaesarora
Rank:Guru Guru
Rating: 88%, 35 votes
IF THE COMPUTER DOESNT READ IT , IT IS CLEAR
1 THE PARTITION TABLE OF THE DRIVE HAS BEEN LOST OR OVER WRITTEN BY SOME ANTIVIRUS SOFTWARE, OR IT MUST HAVE BEEN ACCIDENTALLY SHAKEN WHILE IN USE , OR THE SAFELY REMOVE HARD WARE METHOD WAS NOT FOLLOWED.
SOLUTION
1 CHECK FOR POWERSUPPLY ON THE USB PORT. IT SHOULD GIVE 5 VOLTS
CHECK FOR CONTINUITY ON THE SCAN DISK USUALY FIRST AND LAST PIN (WITH A VOLTMETER HAVING CONTINUITY TESTER.)
IF ALL THIS CANNOT BE DONE BY YOU .
CONTACT FIXYA TO GET MY EMAIL ADDRESS AND LOCATION ND SEND IT TO ME ..
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on scandisk 4.0 cruzer:
I don't want to Accept this solution
Can you Help with these Hard Drives problems?
SanDisk 2GB Cruzer Micro USB Flash Drive...
I want to know how to transfer tracks from a CD to a USB...
My Cruzer 2 GB won;t show up on teh desktop, light comes...
I copied pics from my daughter's computer on to my SanDisk...
My parents philips tv is stuck on the menu screen. I...
i forgot my password to cruzer micro 8gb
Loading problems.
Repair Service
Find Hard Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
