If you have 1 of the newer type code testers, there is a selection on them consisting of yes or no, this is to notify you if you want to remove the trouble code from the system , or not, if you select the yes button to remove the code , it will take the service engine light out, if you do not have 1 of the code testers, then, you can disconnect the positive battety cable for a couple of minutes, then reconnect it, if the light still stays on , go to you closest local auto parts store, let them hook up their code tester, and remove the code for you, hope that this information has been helpful.
