Question about Samsung RB2155SH Bottom Freezer Refrigerator
ONCE THE COMPRESSOR TURNS OFF DOESN'T COME UP BACK ON
I BOUGHT A SAMSUNG RB215SH REFRIGERATOR. AND I HAVE THIS PROBLEM... I REALLY NEED HELP.
I PLUG THE REFRIGERATOR AND IT TURNS ON NORMALLY... IF I LEAVE THE TEMPS AS THEY ARE OR IF I CHANGE THEM TO A LOWER TEMPERATURE... IT HAPPENS NEXT SITUATION....
WHEN THEY GET THE TEMPERATURE THAT HAS BEEN SET THE LEDS STARTS BLINKING THE COMPRESSOR TURNS OFF... AND NEVER COME BACK ON... UNLESS IF I UNPLUG THE REFRIG AND PLUG IT BACK.
  • 3 more comments
  • xeus_16 Jul 24, 2008
    Help!!
  • Stuart Doss
    Stuart Doss Sep 30, 2008
    I have the same problem, somebody's got to take a stab at this!! please!
  • buzzme82 Oct 09, 2008
    Yep, left door ajar over night.
    Nothing happening next morning. Unplugged and plugged back into power point, powered up and all seemed fine.
    Once the set temp is met however, the machine turns off as usual but fails to start up when needed to maintain the temp's.
    If its powered off again, and restarted, it works again but then just repeats the above.
  • Anonymous Jan 19, 2009
    ughhhhh I really hate this fridge...Freezer always freezes up and its only a year old
  • cbolbolian Mar 25, 2009
    I have the same problem. I'm not sure when it turns off, whether it be when it reaches a certain temp or timing. I just know I have to unplug and plug the refrigerator 3 times a day.
    Problem Solver:
  • 15 Answers
The refrigerator is starting defrost mode once four hours of compressor run time has elapsed. Once the computer enters defrost mode it will remain in defrost mode until the desired evaporator temperature is reached (to melt any ice present). However, in my case, the defrost heater was not coming on due to a melted thermal fuse. (one defrost heater and one thermal fuse in each compartment). I found the thermal fuses to be open so I bypassed them. They are made to "open" at 77 degrees farhenheit. Simply storing the appliance in a garage could melt them. Hope this helps!!
Posted on Nov 17, 2008
  • Stuart Doss
    Stuart Doss Nov 17, 2008
    Let me add something: Be careful shorting around/removing the thermal fuse. I placed the defrost sensor too far from the coil and so the defrost heater got a little carried away. The defrost heater got hot enough to melt the blades of the fan. the blades all curled up and eventually contacted the edges of the enclosure. Made a pretty pungent smell. The good news is that the two thermal fuses, a new fan and 2nd day air shipping came to about $44. Not too bad.
  • Stuart Doss
Check thermostate on a samsung side by side frig rs2630sh
Set it to max setting, once compressor starts reduce setting to whatever you want to set it to. It should shut off once it reaches the temp you selected. If the compressor does not come on when set to max, unplug the unit, remove t/stat and jumper the two wires together. Plug it in, if the compressor then starts, replace the t/stat.
Aug 29, 2014 | Samsung RS2630SH Side by Side Refrigerator
Mini Fridge is on but doesn't get cold
Good Afternoon Corey - When any refrigerator is tilted or on its side it needs to be in an upright standing position for approximately 24 hours before being plug in. The freon has to travel down in the lines and it will not function properly until it does so. Locate the unit in a room temperature environment and once the unit is plugged in, it is recommended to wait another 24 hours to place food inside for the temperature to stabilize. Once the compact refrigerator is in operating mode, both the fan and compressor should be running. If it does not, then the unit may possibly have a faulty compressor, relay or sealed system issue. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement because they may or may not have parts available.
May 17, 2013 | Refrigerators
True GDM-10 Drink Cooler from 1997...
A good test method is buy a rco-410 hard start relay. Once you have it, cut an old plug off something and leaving the plug intact, splice the two wires at the cut end with the two wires on thet really that don't have metal ends. Once that is done securly, unplug the fridgem take the really off the compressor and hook up the home made compressor tester. Once plugged in if the compressor is good it will come on, it it doesn't it's bad. This works becuase you remove any variables that are present with the machine hooked up normal.
Jun 15, 2012 | True GDM-10 Refrigerator
Refrigerator Frigidaire model FRS6R5ESBY. My compressor won't turn on but I found the fan motor not working. Will the motor be the fix or is there a way to test before I spend the money?
May 31, 2012 | Frigidaire FRS3R5EMB Side by Side...
Frs26h5as compressor wont run fan in freezer runs relay gud changed defrost time but still no power at compressor plug
The thing is, if the fan in the freezer is running the compressor should be running as well. Here are some questions you should answer in order to solve this problem. When you put the timer on did you do it correctly, I've seen guys have timers with a floating wire and put the wire on the wrong pin. I've also seen timers installed misaligned meaning they were one pin over so only three of the four pins were in. Next, did you check the cold control thermostat. This would kill the compressor but the fans as well. How do you know if the relay is good? Are you sure the compressor isn't getting power, it could be shot and not even trying to come on. A good test method is buy a rco-410 hard start relay. Once you have it, cut an old plug off something and leaving the plug intact, splice the two wires at the cut end with the two wires on thet really that don't have metal ends. Once that is done securly, unplug the fridgem take the really off the compressor and hook up the home made compressor tester. Once plugged in if the compressor is good it will come on, it it doesn't it's bad. This works becuase you remove any variables that are present with the machine hooked up normal.
Apr 28, 2012 | Frigidaire FRS26H5AS Side by Side...
Frigidaire gallery refrigerator ice maker doesn't turn off...no plastic signal bale arm?
Good day!!!!
When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat. Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the refrigerator. Fix or replace the switch if it is faulty.
Modern refrigerators that have a lot of storage and large freezer compartments run for longer periods of time. They also start and stop very frequently to maintain an even temperature. This is especially true if you have just put a lot of warm food in the refrigerator, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a bad thermostat. You may also have the temperature set too high in the refrigerator. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you had it set too high. With the help of a refrigerator thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize. The refrigerator should be at least one half to two thirds full. This will help to maintain a stable temperature inside the unit. The cold items inside will help to keep an even temperature inside after the door has been opened and closed. Some people prefer to keep a lot of stuff in the refrigerator as ballast, even jugs of water. This helps to maintain temperatures inside so that when the door gets opened and closed often, it doesn't need to run as much to maintain the temperature inside.
I hope this information will be helpful...Thanks for using fixya...
Aug 31, 2011 | Refrigerators
Samsung rs2530bbp... Not cooling... Compressor
my frigerator RS2530BSH has the EXACT same problem! can anyone help??
Jan 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Not cooling and has a clicking sound
hi friend,
Refrigerator Not Cooling Is your Refrigerator not cooling? This Refrigerator repair guide will walk you through the procedure of repairing your refrigerator. This is the same procedure I go through every time I check a refrigerator. So with a little from this refrigerator repair guide your refrigerator will up and running in no time. Below is a list of problems that can cause your problem. Read through each one carefully until you find and repair your refrigerator. If you decide that you need a part in order to repair your appliance, you can Buy appliance parts on-line and save.show?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 It’s easy! Just find the model number of the appliance you are working on. Next, type it in to the model number box and it will take you to an illustrated parts diagram for your appliance. Then just simply choose the part you need from the diagram. If you need help finding your model number click here
DEFROST Defrost can be the cause for your refrigerator not cooling problem. To check to see if you have a defrost problem, look in the freezer to see if there is ice build up on the evaporator cover. (The evaporator covers are either in the back of the freezer or on the bottom of the freezer). If there is ice build up click here. refrigerator not cooling If not, keep reading on.
Top-freezer Leaking/Refrigerator Not Cooling On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
DIRTY CONDENSER Dirty condenser can be the cause for your refrigerator not cooling problem.. If the condenser is dirty, the compressor will cut off on the overload. (A thermostat that is on the side of the compressor that cuts it off if it overheats). Often when this happens you’ll hear a clicking noise about 2 to 3 minutes apart. This is your compressor cutting in and out as it overheats and cools off. Now you need to find out why the compressor is overheating. First you’re going to need to remove the cover from the back of the refrigerator. Once you remove the cover you should see the compressor. Now look at the condensing coils (condensing coils are going to be either behind the compressor, beside the compressor or on the back of the refrigerator) to see if they are dirty if so clean them. To clean the condenser I normally use a brush made for this. You can buy them at Wal-Mart. Once clean your problem may be fixed. Leave refrigerator unplugged for a while (20 min. or so). Then plug it back in and if the compressor doesn’t overheat problem is fixed. If it still overheats read on.
START RELAY (Compressor clicking won’t start) The start relay can also cause the fresh food and the freezer sections not to work. If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Then take the cover off that is on the side of the compressor. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing).
STUCK IN DEFROST If your refrigerator is stuck in defrost, this can be the cause for your refrigerator not cooling problem. Just simply turn the defrost timer a ¼ turn. Defrost timers are normally located in the fresh food section near the controls or at bottom behind kick plate. If the refrigerator comes on replace timer. If your refrigerator is newer, the timer may be electronic; therefore, you can’t do this. But it can still be your problem, although I haven’t seen this often.
COLD CONTROL The cold control can be the cause for your refrigerator not cooling problem. This is the least likely of all the problems but happens sometimes. Turn the control up all the way and tap on it. If the refrigerator comes on then replace cold control. If it still doesn’t come on, it may still be bad. You can check it by first unplugging the refrigerator and taking the control out and test it with an . ohmmeter Unplug the wires and see if you have continuity between the terminals, if not replace control.
MAIN CONTROL BOARD Some newer refrigerators have a main control board and this can be the cause for your refrigerator not cooling problem. This can be hard to diagnose if you don’t have a wiring diagram or don’t know how read one. I can’t help you because I would need a wiring diagram of your refrigerator to diagnose a main board.
thank u for using fixya
regards,
sivaranjini
Aug 06, 2009 | Kenmore Refrigerators
"Help" Missing refrigerator door sensor & compressor is continuously running..
could be, since if the computer senses that the doors are open, then he would turn the compressor continuously in order to compensate for the losses of an open door refrigerator.
but with this kind of alarm, im sure it should have turn the refrigerator off if it has been sensing that the doors are open for the past 48 hours.
another thing to consider is that since it is second hand, it could have been repaired and things done to it for the compressor to run continuous.
tnx 4 using fixya,
drcool
Aug 12, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
No cooling
Try putting it in test mode. Easiest way is to take cover off of board and look for little test button. Press once and fans and compressor should come on. Press twice the damper will close. press three times will go into defrost, ( only if it is cold in freezer) otherwise comes out of test mode. Press 4th time and comes out of test mode.
Do you have any error codes displayed?
Sgt 48
May 23, 2008 | LG LRFD25850 French Door Refrigerator
Samsung RB2155SH Bottom Freezer Refrigerator Logo
402 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
