Question about Microsoft Windows 2000 Professional for PC
My opreting system is errer
That time showing in debug errer
  • Jamie Lynn Belanger Banta
    Can you please post exactly what the error says?
    Novelist:
  • 202 Answers
Please I Kindly ask u to describe completely about u r computer problem or write that error on a piece of paper and type with full details when that problem u faced
Always Explain Briefly So that once when we read u r Problem we will get a clear picture of the problem
Posted on Aug 03, 2008
Chek smos errer
You have described you problem incorrectly. I guess the error mess is "CMOS Cheksome error. " I guess.
This messenger comes due to following situations.
1. CMOS battery low. Check for the CMOS battery (most commonly CR2032) power if it is low this message can appear.
2. BIOS has been reset on purpose or by a fault. Set time date and other settings.
3. Motherboard problem. Rarely motherboard will have this issue with CMOS or with the battery powerline making it to lose CMOS Setteings. Change the motherboard or live with it.
Regards
Apr 01, 2014 | Computers & Internet
My lap top model is tecra m3 and it takes 2 houres to boot opreting system until it boootes it showes tosheba on the screen
Go to www.download.com Type ccleaner and install and run the program, next install malwarebytes anti- malware and do a full scan after definitions have been updated, finally run defrag to improve performance.
Jul 07, 2012 | HEWLETT-PACKARD ProBook 4420s Notebook
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
May 29, 2010 | Dell Studio XPS 16 Notebook
I m using vista home premium 64 bit opreting system & i am unable to run some of the softwares that run on 32 bit OS like TURBO c/c++ compiler. every time i try to run it it shows the message "the...
There are compatability issues with many of the 32 bit software titles. The 64 bit version of Vista is not backwards compatable with all titles of 32 bit Vista. You will have to down load the patch or 64 bit version of the titles you are having trouble with. You can try to run it in compatability mode but things like Turbo C/C++ will not function in that mode correctly. They won't debug right.
Oct 12, 2009 | Microsoft Windows Vista Ultimate Edition
Need to remove a dell 1150 administrator bio password
You can also delete the BIOS password from the dos prompt! (Not sure it works in NT/w2k/xp if you are using it boot from a floppy) Here is what you should do:
At the C:\> prompt, type:
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Q
and hit Enter one last time, to quit DEBUG, back to the C:\> prompt.
After that just reboot the computer and enter the BIOS!
Oct 11, 2009 | Computers & Internet
Display properties
Download this, run it, and click Yes when it asks if you want to "add this information to the registry."
http://www.kellys-korner-xp.com/reg...
Let me know how you made out, and please rate my answer.
Jan 17, 2009 | Dell Dimension 4600 PC Desktop
Codings
errer is debug?
Jul 24, 2008 | Computers & Internet
Microsoft Windows 2000 Professional for PC Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
