Question about Dell Inspiron 5160 Notebook
Dell Inspiron 5150
When I go to start the computer, I get a black screen and the only thing that shows up is the cursor in the upper left corner?
    Genius:
  • 2,028 Answers
This can be caused by a bad memory chip, but most of the time the hard drive has failed or bad sector that it's unable to read from. If your machine has a diagnostic or hard drive test in the bios, run it. Some also have a memory test that you can run. If yours does have these and any part of the hard drive or memory test fails, the there's your problem. If you don't have these, the start by removing the memory and trying them one at a time. If this doesn't work, then reformat the hard drive and reinstall the operating system. If you have any problems during or after the format and reload, then the hard drive has failed and will need replaced.
Posted on Jul 24, 2008
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
When I push the power button, the main dell start up screen comes on followed by a black screen with a blinking cursor in the upper left corner. It uses Windows 7
Remove any CD's or USB drives 1st.
Sound like its trying to load and can't find hard drive, CD, or USB device. You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key to press during boot. Make internal hard drive first. Save and restart. Reseat hard drive if it does not show up in BIOS.
Oct 05, 2012 | Dell Inspiron 560 PC Desktop
Dell Inspiron mini 10. The system will not boot up, after the Dell logo screen and blue bar goes away, the screen is blank and the curser is flashing in the upper left corner of the screen. F11 isn't...
That cursor indicated that the BIOS can't find an Windows installed on the hdd. Since even the recovery partition appears to be inaccessible the only thing left is to reinstall it using the recovery cd that should have come with it when you bought it If you don't have it you can order it from Dell.
Sep 01, 2011 | Dell Inspiron Mini 1012 Netbook...
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
Blank screen on start up. No dell logo. Only
have u tried resetting it (u may loose it all)
Apr 14, 2010 | Dell Inspiron 5150 Notebook
Black Screen
try booting from a cd like the reinstall cd for windows that came with the computer. when starting hit F12 to show 1 time boot menu; select cd drive; hit any key when asked to boot from cd. This will tell you if its a software or hard drive problem.
Feb 18, 2009 | Dell Inspiron 1525 Notebook
Windows will not start/run.
Try tapping the F8 key while starting up the computer to see if it will start in safemode. If the computer will not start in safemode you may have a failed hard drive that needs to be replaced. If you do get the computer to start in safemode backup all your data and then perform a CHKDSK (check disk) on your hard drive by right clicking on your c drive and going properties and then to tools then checkdisk.
Feb 16, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron 5160 Notebook Logo
89 people viewed this question
Alun Cox
