posted by accardi on Jul 24, 2008
I have a IBM Lexmark WheelWriter 1000 typewriter. The right side of the typewriter where you usually have your lights (i.e bold, caps lock, lang, re PRT) are all lit up. The part inside where the ribbon cartridge is does not go back and forth when you first turn it on, and if you hit any key it doesnt respond.
Is this typewriter fixable?
Andrea
Solution #1
posted on Aug 02, 2008
Anything can be fixed. If you send it to us we will give yuo a free estimate.
DickyO
Cleveland Business Machines
2419 St. Clair Ave.
Cleveland, Ohio
216=242=0027
DickyO
2419 St. Clair Ave.
Cleveland, Ohio
216=242=0027
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 25, 2008
It could be a bad carrier return motor or the carrier is stuck . Turn it off and try to move the carrier left and right it should move with light pressure if it don't try wiping the round rail it slides on with a light oil then work it back and forth a few times repeat until it moves when turned on.
Suggest a new solution for this problem
Post a New problem for Lexmark Wheelwriter 1000 Typewriter
Email this problem
Email this problem
Can you Help with these Typewriters problems?
Repair Service
Find Typewriter Repairman Near You:
