Question about HP LaserJet 4 plus Printer
'14 no toner cart' problem to be solve
My printer keeps telling me '14 no toner cart' even if there is a full one inside. Is anyone able to help me on that?
Thank you
Pascal
  • Anonymous Oct 23, 2008
    xcz
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
It has a chip on the toner cartridge, chip is bad. replace
Sometimes the sensor in the machine goes bad. replace
Posted on Aug 08, 2008
I could not able to print a page in my printer
Posted on Oct 23, 2008
Why does richo aficio 2016 copier keep asking for toner hen toner is full
As long as the toner sensor senses it is empty, it will keep telling this. Or the sensor is defect, or a cable came lose, or perhaps you only have to shake the toner cartridge a few times. Be aware it is open now.
Jul 16, 2014 | Ricoh Aficio 2016 All-In-One Laser Printer
RESET TONER COUNTER
why????????? which color???? did you refill a cartridge????? most cart have electronic chips on them once done tells copier i am done so you if replace the toner inside the old cart to the copier the cart is still old
Feb 20, 2014 | Konica Minolta magicolor 4750EN Laser...
Minolta 8650 problem c-2a01
loo like you replaced the cyan toner cart.. (with the machine powered off and unplugged) take a look inside the machine with the cyan toner cart out.. make sure that nothing is blocking the metal contacts or if there are dirty contacts. perhaps there is a piece of debris that is blocking the connection of the new toner cart to the printer. another thing to check is the contacts on the toner cart its self.
Jan 02, 2014 | Office Equipment & Supplies
Just purchased a used HP LaserJet 4 Plus -- when turned on and installed it is showing 14 no EP CART -- we do not use cartridges so need to reset to default settings. Tried Power On and holding online but...
Ensure that the Toner Cartridge is installed correctly (fully
seated into the printer). Try a new Toner Cartridge. If the
problem continues, try this
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 Reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller.
Jul 05, 2011 | Office Equipment & Supplies
14 no toner cart
when top door , and check for the sensor switch
Jun 17, 2010 | HP LaserJet 4 plus Printer
Dark printout
Have you tried a different toner cart? Common problem with reman carts. If that fails again, check the silver spring loaded contacts inside on the left and right that contacts the toner cart. Make sure they are not stuck inside the frame and that they are springy.
Aug 04, 2009 | HP LaserJet 5200tn Printer
Error code 14 "no tuner cart"
1 reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
May 06, 2009 | HP LaserJet 4 plus Printer
Yellow color not recognized.. how to solve this? full ink cartiridge..
Turn off printer. Reseat all the toner cartridges. Power on printer .. If still a problem turn off and remove all cartiridges and use vacume to remove any excess toner. Use canned air to clean any sensors. Turn the yellow carts gears and see if you have any binds. replace all carts and power on.Problem should be solved. If not, try a different yellow cart.
Mar 04, 2009 | Office Equipment & Supplies
Problem with aficio 1035
The developer should probably be changed in it. the cartridge should be inspected as well. Was there any toner spills?
Jun 21, 2008 | Ricoh Aficio 1035 Copier
HP LaserJet 4 plus Printer Logo
1,426 people viewed this question
Seeker5211
Seeker5211
