Sharp a/c-#AF-S85FX a/c cut off--code E1--removed and cleaned filter, but a/c won't reset--runs for a few minutes then stops flashing E!
  • 143 Answers
The e1 code is operated by a timer which stops the machine every 720 hours of run time. There are 2 procedures to reset this.
1) unplug the machine. Hold down the power button while plugging it back in and waiting for a beep of about 5 seconds duration. Release the power button. Unplug the machine again. Resume trying to use it as an air conditioner.
2) unplug the machine. Hold down the Mode button while plugging it back in and waiting for a 3 second beep. Release the mode button. The machine will start. turn it off by pressing the power button. Resume trying to use the air conditioner.
If these do not work, the "clean filter timer" is broken and will require you to replace some parts.
(Aren't you glad there is a computer is almost everything?)
Posted on Jul 25, 2008
Turning off code e1 flashing what is e1 code
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
I have a Sharp AF-S80FX A.C. unit. Whether on cool or fan the unit keeps tripping the breaker on the plug with an E1 message. The filter has been removed and cleaned, but it really wasn't dirty.
small_16_7.jpg For a detailed Air Conditioner illustration, click below.
redarrow.gif Window
It doesn't turn on at all
The fan runs but there's no cold air
The air is cool but doesn't seem cold enough
The unit never turns off
There is water sloshing around inside
The unit tries to start for a few seconds and then quits
A motor is running but there is no air blowing
The unit rattles loudly when it turns off
Water leaks out the front of the unit
The air smells musty
Note: If your repair problem isn't listed, click here
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas:
Jul 10, 2008 | Sharp Heating & Cooling
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
E1 ERRORE COMES IN M Y AC WHICH REASONS
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
panel.
button.
the instructions above EXACTLY.
  • Date: 5 Aug 2005 06:33:46 -0700
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error Code
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Mar 01, 2011 | Heating & Cooling
Ei flashing display unit power cutoff
E1 MEANS FILTER CLEAN AND THEN CHECK IF STILL ON THIS IS ASOFTWARE PROB CAN BE DONE ONLY BY THE SEALER SUPPORT.
Aug 31, 2009 | Sharp AF-S85FX Wall/Window Air Conditioner
E1 Flashing on display, air cut off
There are steps listed in the user manual which can be downloaded from:
http://www.sharpusa.com/...
/air_man_AFS60FX_S80FX_S85FX_R80FX.pdf
You also need to hold the power button when plugged back in. If that doesn't work, there is another step as well.
Aug 23, 2009 | Sharp AF-S85FX Wall/Window Air Conditioner
AIR CONDITIONER MODEL #AF-S85FX--CODE E1 COMES ON-CLEANED FILTER, BUT UNIT WONT RESET AND KEEPS DEFAULTING BACK TO CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Jul 24, 2008 | Heating & Cooling
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Aug 02, 2007 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
290 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
