HP Photosmart 475 -- followup
Hi again. Thanks for response. I should tell you, however, that the rollers are in the back of the printer, where you place your paper to feed through the printer. I got the door open a bit and cleaned the rollers as best I could; however, I see no improvement on feeding the paper through at all. This printer seemed to feed the glossy photo paper I got at Costco just fine when the printer was new;however, now that it has had some use, it just doesn't want to feed the glossy paper for some reason. Sometimes it takes 25 tries for me to get it to feed, if then. I have read the manual and gone on line at HP too and done everything they suggest. HP gives absolutely no instruction about cleaning the rollers in its operation manual nor its website. It DOES say that the problem could be the type of photo paper you are using, but it used to feed this paper just fine. It may be that paper by HP (three times more expensive) will do the trick....just very irritating as I can't afford that paper!
  • Anonymous Mar 05, 2009
    My HP Photosmart C6150 will not feed the costco photo paper - i have tried more than a dozen times and it won't work - i have never had this problem with other paper
  • jws55 Apr 14, 2009
    I've got a cheap HP Photosmart C1350 that was doing just fine with non HP papers, (regular and photo), and I too am having problems with the Costco photo paper. The print surface feels kind of grabby with a lot of friction to the touch. My other photo papers didn't feel that way and fed right through. Some beach.
I droped my HP photosmart 475 and the front came off. There is a small white part that came out, I do not know where it goes, it still works.
Posted on Jul 10, 2010
How to clean the paper rollers for a HPC7280 printer?
This procedure was developed to assist the user in cleaning the rollers that feed the paper into
your inkjet printer.
I share a informative links, please open link and read documents.
More Help Click..
How to Clean HP Printer Rollers
http://www.museofineart.com/~museart/index.php/download_file/view/110/77/
Thanks,
HP Printer Support
Jun 24, 2014 | HP Photosmart C7280 Printer
My hp photosmart 475 will not print 5 x 7, how do I change it?
that is in the printer settings when printing a document or photo if the original is larger or smaller, then you need to select that size from the printer settings panel when trying to print.
this link may help too
May 17, 2012 | HP Refurbished Photosmart 475 Compact...
My hp photosmart 8250 keep showing paper jam but there's no paper jam anywhere. How can I get it to function properly?
Make sure there is no paper stuck inside in the paper. may be there is small piece of paper stuck inside
Just unplug the power and open the cover and remove the toner or cartridges from the printer and manually try to roll the roller and remove the paper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | HP Hewlett Packard Photosmart 8250 InkJet...
How to clean
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Need a user manual for HP photosmart 475
hello, yes you can dowload it from the hp website in PDF format.
HERE
Feb 23, 2009 | HP Photosmart 475 GoGo InkJet Printer
Printer carraige of hp photosmart 475 has jammed at the far end
unplug the device and try to move the carriage with your hand ,but do not force to move it .if it does not moves just again plug in the wire and on the printer.and the carriage will move when the carriage comes out.just check out the cartridges that r they properly installed.
Nov 29, 2008 | HP Photosmart 475 InkJet Printer
HP Photosmart 475 printer
The rollers should be in front of the printer. I have never opened one of these before but have worked on a Kodak. Try using a flat screwdriver with a cloth wrapped around it to clean the rollers. Just be careful not to damage the rollers with the sharp end of the screwdriver.
Jul 18, 2008 | Office Equipment & Supplies
187 people viewed this question
jasbo
jasbo
