I have an admiral tumble dryer which started making an rubbing noise once it got warm. Now making it all the time I cannot find any breakdown of parts to see what it might be. Can you help?
  • mule65 Nov 19, 2008
    admiral dryer making loud noise but still drying fine? model #ADE7005AYW serial # 11624488JJ
  • Anonymous Feb 06, 2009
    My dryer with the same model number is doing the same thing. Pretty frustrating since it's only 29 months old.
THanks I bought the part you told me to. Thanks for your help.
Posted on Jul 25, 2008
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 | Dryers
And Admiral ser# 3281223 When dryer is turned on, it makes a loud grinding sound when it tumbles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 29, 2011 | Dryers
My Admiral M938 Gas dryer will start to tumble but makes a wierd noise then stops tumbling and just hums.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Whirlpool Dryers
HI, MY ADMIRAL TUMBLE DRYER WILL NOT START. THERE
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Aug 28, 2010 | Dryers
Admiral dryer started rubbing metal to metal what
A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 15, 2009 | Dryers
CREDA TCR2 TUMBLE DRYER
put it in the bin
Sep 12, 2008 | Dryers
Loud squeaking noise on an admiral elec. dryer ADE7005AYW. Where do I find a breakdown diagram, also? Thanks Steve
The most common cause for this noise is a failed belt idler pulley. Lubricating is a temporary solution and will not last, the noise will return. You can get a parts list and breakdown at this website: http://www.searspartsdirect.com.
If you need further assistance, let me know
Regards,
reg501
Jul 19, 2008 | Dryers
My noisy hoover tumble dryer...help please!
possibly bearings gone on drum shaft
Mar 20, 2008 | Dryers
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
