Question about Whirlpool Duet GHW9150P Front Load Washer
Water keeps filling in washer
There are no error codes, the washer is off, but the water keeps slowly filling up in there.  I just do the drain/spin cycle to get it out, but it just keeps filling up again.
  • 2 more comments
  • ggoldner Jul 24, 2008
    Same as the last post. Keeps filling over 2 days time have to run Drain/Spin cycle. Have to turn off valve when leaving. Afraid it will overflow.
  • Anonymous Jul 24, 2008
    mine does too--however not every time just intermittently
  • Anonymous Mar 05, 2009
    I have the same problem and this looks like great information.
    I'll order the part and let you know.
    If it work's I'll buy you a 6 pack of your favorite beer.
  • bader_sophia
    bader_sophia Jan 07, 2013
    Me Too!
  • 246 Answers
Sounds like you need a new water valve (some debris inside the valve causing it to not fully close). These are availible from your local appliance parts store or on line from the manufacture. Once you have your replacement, just take the #20 torx screws out of the rear of the top panel slide the whole panel slightly towards the rear and lift it off. On the outside of the washer on the back panel, You should a light blue plastic thing that the 2 matching hoses from your house connect to. Turn your water off and remove these hoses. Just beside them you will find another #20 torx bit screw (some models use a #10 or #15). Remove this screw as well. Now from the inside of the machine, you will see 4 blue wires going into 2 connectors on the valve. Remove these connectors only by pulling on the connectors, not the wires. Lastly you will see a small black hose with a green or silver clamp on it. Squeeze the clamp with a pair of pliers and then slide it down the hose. The hose should now pull free of your old valve.
Please remember to rate this information if it was helpful to you. Best of luck and drop me a note if you have any troubles.
Posted on Jul 25, 2008
3 Suggested Answers
  • 48 Answers
SOURCE: The washer fills slowly with water when not in
Most likely the water inlet valves on your washing machine have failed. You may have noticed larger amounts of water in the clothes drum when the washing machine hasn't been used for a few days, this is because the valves may still be open allowing water to drip into the clothes drum.
Here is a link to the part that you need to buy: http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Washer-water-inlet-valve--universal-item-number-AP3098982.aspx.
And a link to a video showing you how to replace the part: http://www.ultimatehandyman.org/video/appliance_repair/water-inlet-valve.php
Hope this helps!
Posted on Feb 28, 2011
jumptrout51
  • 3361 Answers
SOURCE: After the wash cycle is complete and the clothes
Your water fill valve is defective. This is a fairly common problem.
This video,while not specific to the water valve will show you how to remove the cabinet to access the water valve.
The water valve is the part the water hoses connect to.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
Posted on Dec 20, 2009
Testimonial: "Very quick and accurate response. Thank you very much. The part is removed and I'll find the replacment part tomorrow."
Washer fills with water when not in use. Doesn't completely drain and spin cloths, and I get an E10 error code
Hello Lahoma, thank you for your post!
I understand that your Frigidaire washer fills with water, will not drain completely, and is flashing an "E10" error code. The error code stands for your washer fill time is too long. This could be an issue with your water valve, main control, or water pressure. You should check to make sure that your water flow is normal and that your water line is not restricted. This could cause an issue with the way water is distributed within your washer. The water pressure coming into your washer should be at 30 PSI. You can also clear out any false error codes by performing a reset on your washer. In order to reset your washer you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue I would recommend consulting with a professional technician for a proper diagnosis to be completed. I hope this information is helpful to some degree. -Matt
Mar 18, 2015 | Frigidaire Washing Machines
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Sep 09, 2009 | GE WBSR3140DW Top Load Washer
Gets to the spin cycle and does not spin and drain
What is error code?
Does unit spin?
Does unit drain?
Does unit fill on all water settings?
Ie set to hot, warm, and cold and see if fills.
Jul 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Keep getting SL error code
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer failure
Sep 27, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
501 people viewed this question
Dan Webster
Dan Webster
Sal De
