FixYa.com
Tags:
Hobart 1,491 Watts H600 Stand Mixer
Hobart 140 Qt Mixer 4 speed. needs the oil changed?...
posted by onlyonenuno on Jul 24, 2008
So its been a few years since I bought it and I have neever had the oil changed.
Would like to change the oil but not sure what kind to use, or best place to buy the oil.
Thanks Nuno
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 26, 2008
Helpful (85)
bigg t
Rank:Guru Guru
Rating: 85%, 338 votes
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Rating Locked! (?) onlyonenuno has rated this solution as Helpful
Can you Help with these Mixers problems?
Mixers
bravetta mixer
I have a practically brand new... Answer This...
Mixers
mixer not working properly
beater scrapes side of bowl.... Answer This...
Mixers
oil seal
I have to chang oil seal hobart... Answer This...
Mixers
can't find replacement beaters...
My friend has a Euro-Pro model... Answer This...
Mixers
Disassemble a Hobart Mixer...
I am trying to pull out the... Answer This...
Repair Service
Find Mixer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
