Question about Samsung Cell Phones
Cannot remove batterie to put new one in - Samsung Cell Phones
    Genius:
  • 1,011 Answers
Dear,
what kind of mobile u have. then it will be suggested
Posted on Jul 24, 2008
How do I change the battery
Undo the straps securing the battery.
The complicated bit. To save problems with cutting power to your radio and the ECM, you need to maintain power as you change the batteries over. Place the new battery on the side of the engine bay, in the right attitude to drop it into place. Take two pieces of insulated wire and twist it around the bottom of the terminals on the new battery, and the other end to the clamps on the old battery.
Remove the clamps on the old battery, and place it on the other side of the engine bay. Put the new battery into place. Put the clamps onto the new battery and slide them down. Tighten them loosely. Remove the wires from the bottom of the terminal and tap the clamps down and fully tighten.
Replace the holding strap.
Oct 28, 2015 | Cars & Trucks
How do i change the starter in my 1993 camero
disconnect the red terminal from battery. jack up car enough to get under. secure with jack stands. near rear of engine under car, is the starter. unplug electrical harness from starter. remove bolts. as you remove the bolts, starter will come down. remove, put new one in. put bolts in, tighten bolts. plug electricfal harness in to new starter. lower car from jack stands. connect red terminal to battery. if you have an alarm, put key in ignition to on position before connecting battery.
Sep 18, 2010 | 1993 Chevrolet Camaro
T23 laptop. Put in new battery. WIth battery in
poor battery contacts or dead battery cell doing this flickering
replace the battery if contacts are clean inside the computer
Jul 06, 2010 | IBM ThinkPad T23 2647 Notebook
I need info on how to switch the case out
There is no written instructions. I looked online but there isn't any.
Follow this instructions
1)with the game-boy screen facing you, there are 5 round things there.
3 up and 2 down the screen.
2) put your screw driver inside there and remove it. Do it to all of them.
3) there are screw(nuts) inside those round things. so remove the screws(5) with the screw driver.
4)Don't open the LCD yet. Turn to the back of your gameboy, there you see 6 srews(nuts). 2 up one middle(for the battery) and 3 down. Remove the screws.
5) after you remove all 6 screws, the middle screw is for the battery. open the cover now the screw is gone and remove the battery.
(please remove any screw you see where the was before)
6) Open your game-boy with knife or with anything possible for you then the screen.
remove any screw on the board inside of the game-boy.
slowly and carefully disconnect a cable that is connected to the motherboard( LCD cable)
7) remove the speaker and then transfer it to the new skin, remove all the buttons and transfer then, now put the motherboard to the new skin, remove the Screen(LCD) then transfer it to the new skin. put the LCD cable you disconnect from the motherboard back. put the motherboard screw back. put the LCD screw back.
8) Turn to the back of the game-boy and put the battery back and all crews back. Now you are set enjoy!!!. feel free to ask me any question.
Jan 24, 2010 | Nintendo Game Boy Advance SP Console
How do you access battery to put in new one 1993
remove seat battery should be in the middle remove rubber strap,undo both cables pull battery up and out..
Jan 23, 2010 | 1993 kawasaki ZXR 750
Changed battery on 2003 toyota echo but when i put the new one in and start i have no power the new battery is fully charged 12.7 volts put old battery back in car starts is there a special procedure for...
Check the new battery posts(connections if side terminal) alot of the battery companies put a protective coating on and it has to be removed. Use wire brush or sandpaper to clean them and you should be fine.
Dec 03, 2009 | 2001 Toyota Echo
Need instructions on how to change the battery on my 1999 300M?
You need to remove the panel from in front of the passenger side front tire to access the battery. You will also have to remove the air filter housing to get at the battery hold down so you can remove the battery. Hope this helped.
Hope it helps and have a great day!
Jun 15, 2009 | 1999 Chrysler 300M
Cant figure out how to open back of phone to put in new battery
First: you need to simply remove the back; then after you remove the back the battery will be there. If it wasnt removed simply remove the battery from the back of the phone without it getting wet. There might be some slight difculty doing this. What you have to do is ; slam the back of you're phone; on you're thigh if you have anyproblems. also place the sim card in behind the battery u will find the sim card slot; . Then place it in the slot facing up wards.
Thank You; :-* Hope it works!
May 02, 2009 | T-Mobile Sidekick II
How to put new fascias on w910i helllllllllllllp
  1. Turn off the phone.
  2. Remove the 4 screw covers on the back of the phone, 2 on the top of the main body and 2 at the top of the slider.
  3. Take out the 2 screws at the top of the main body.
  4. There is a 3rd screw on the right hand side of the phone above battery pack, take this out. dont forget where each screw came from.
  5. you can now remove the back plate.
  6. next you will need to remove the 2 screws on the top of the slider.
  7. Remove the battery pack.
  8. (make sure the slider is OPEN) You will see two screws on either side of where the battery pack was. Remove these.
  9. You can now Remove the front plate.
Bassically uncrew all the screws. take it apart, put your new stuff on and then do everything again backwards.
Mar 25, 2009 | Sony Ericsson W910i Cellular Phone
Samsung digimax s700
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Samsung Digimax A400 Digital Camera
Cell Phones Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
