Question about Pioneer PRO-200 60" Rear Projection Television
Pro-119 power light does not even turn to red.
Unit is hooked up to surge protector, I unpluged the unit for about ten minutes per intstruction manuel and still I get no power to unit.
    Genius:
  • 2,785 Answers
Plz try with the mains for some time if still you are not getting any power then your unit have to be serviced
Posted on Jul 24, 2008
    Sergeant:
    Champion:
  • 310 Answers
Check the fuse or power cable....................
I had a power surge about a month ago and now my wii will not turn on. My wii is pluged into a surge protector.
I posted this elsewhere on here too, but I'll post it here too so it helps you.
This is a common problem with the Wii. You wouldn't believe how often I read about this. I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 09, 2009 | Nintendo Wii Console
Wii will not turn on even though it has power and everything is connected. Help?
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Can't turn wii back on
Did you unplug it from the Wii, or from the Wall Outlet? You need to unplug it from the wall outlet, not the Wii. If you haven't unplugged it from the wall outlet and left it unplugged for 5 to 10 minutes, then unplug it from the wall outlet and leave unplugged for a good 5 to 10 minutes.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself, so power to the AC adapter needs to be cut off.
Dec 08, 2009 | Nintendo Wii Console
The wii was unplugged inadvertantly, once plugged back in it won't turn on...red light does not come on...what are the possible reasons ...cable had gone out earlier in day and had to reboot
You most likely need to reset the AC adapter.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. You plug it back in, the power comes on, but it appears dead. The problem is with the AC adapter, not the Wii itself.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up, and it should work.
My nintendo has no power going to it even tho the a/c adapter is hooked up
You'll need to unplug the AC adapter from the wall outlet and leave in unplugged for 5- or 10 minutes or so. Unplugging it from the Wii does no good.
This is a common problem with the Wii. As I said, I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked upto a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 04, 2009 | Nintendo Wii Console
After not using my wii for about a month i went to play it the other day and it wouldn't turn on. The indicator light on the power button is off, not green, red, or orange. All the cords are connected, I...
Unplug it from the wall outlet (NOT from the Wii). Leave it unplugged for a good 5 to 10 minutes. The AC adapter needs to be reset (more on that below).
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
Dec 03, 2009 | Nintendo Wii Console
Wii work for 3 weeks will not turn on .
There is no light on the front, correct? No red, yellow or green?
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. This is a common problem with the Wii. It happens almost every time there is a power surge or the power goes out, etc. Even if it's hooked up to a surge protector, this happens.
Power will come back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Nov 30, 2009 | Nintendo Wii Console
No power to unit. Used all cord removed and power
Make sure to wait long enough during power disconnection. Unplug the power adapter at both ends (at the console and especially at the power outlet). Give the capacitors at least a minute (perhaps longer) to completely dissipate residual energy. Then, hook it back up and it should be good to go.
If the power light does not come back on, even after wait several minutes. The power adapter will likely need to be replaced. Any electronics shop will be able to test the power adapter first to be sure it is the problem.
I would give credit to someone else for this super simple solution. But, it's all over the internet.
Nov 25, 2009 | Nintendo Wii Console
My wii won't power up. I am not sure what is wrong, but it won't turn on.
I just posted this somewhere else where this was asked, but I'll post it here too so it helps other people.
Aug 05, 2009 | Nintendo Wii Console
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
Pioneer PRO-200 60" Rear Projection Television Logo
46 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
