Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
Default gateway why after pinging the default gateway address,it displays "Request time out?"
  • D-Link Master
  • 32,281 Answers
When you ping the gateway with your computer it could not communicate with the gateway.
Assuming you are connecting via a network cable.
Either the network cable is broken or network card is faulty or it is configured incorrectly.
Make sure your TCP/IP address of your network card has the same TCP/IP address range as your gateway.
Posted on Jul 25, 2008
D-Link problems
open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway, it should be your IP address.
If you are still unable to browse the Internet, ping your router's connection to the PC. Open Command Prompt, type 'ping 192.168.0.1', hit Enter. If your PC is receiving connection from your router device, you will see a message like Reply from 192.168.0.1: bytes etc. If there is no connection, you may see the Request timed out message.
The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
If you need any kind of technical assistance you can contact support cell at here
Jan 23, 2013 | D-Link DIR-628 Wireless Router
My computer can't connect to the internet and i don't know if I lost a driver or I need a new ethernet card?
Hi, to check if your ethernet card is working, follow this instruction to check the presence of your lan card driver.,
For wired/wireless connection,
1. on your desktop right click my computer/properties/hardware/device manager
2. in device manager locate the network adapters, click + sign to expand the content. in your network adapters folder there should be the list of installed driver with no X sign or exclamation mark which means it is installed but disable. If disable, right click the icon and tick the enable option. The presence of the driver is the same with both wireless and wired connection.
The other one is, right click the Network Neighborhood icon on the desktop and select properties, inside the properties it will display, Local Area connection or wireless connection, the one your were choosing must have an status of connected,an icon with two small monitors cascading.
If no drivers installed, Install the driver, if there is hereunder is the next isolation.
The other thing also is to check your connectivity, go to your command prompt and at your c:\ prompt type c:\ipconfig /all then enter, it will display your IP address and gateway.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connecti
on
Physical Address. . . . . . . . . : 00-01-E7-6C34-11
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.253.111
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.253.253
DNS Servers . . . . . . . . . . . : 192.168.253.253
To check if your have internet connectivity type in your c:\ prompt
c:\ping ip address of your gateway {sample c:\>ping 192.168.253.253 then enter, it will prompt like this if connected
C:\>ping 192.168.253.253 -t
Pinging 192.168.253.253 with 32 bytes of data:
Reply from 192.168.253.253: bytes=32 time<1ms TTL=254
Reply from 192.168.253.253: bytes=32 time=1ms TTL=254
if no connection it will display.
Request time out.
Jun 27, 2011 | Dell Dimension 1100 PC Desktop
How to gateway ping
jaykid18
The first thing you to check is to see if you are able to ping through your computer firewall. This link will help you check this.
How to allow ping (ICMP Echo) request through Windows 7 Firewall
Next you will need to know what the IP address of you Gateway is. If you do not know what it is the link below will help you find out what your Gateway IP address is.
http://www.fixya.com/support/r4935363-determine_computers_ip_address
After you have the IP address to your Gateway you will need to ping the address. If you need help doing this link will help you do this.
http://www.fixya.com/support/r6097326-ping_ip_address_in_windows
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 21, 2010 | Belkin (F5D8231-4) Wireless Router...
LAN Network, both PC's with static IP's and defaullt and DNS addresses are 192.1683.1.1 tried the other defaults. Both machines connected. when i ping each others IP's request timed out. please help
Can not really understand what exactly you have done. Please try the following steps:
1. Assign static IP on pc 1 as 192.168.1.2 assign subnet mask as 255.255.255.0. 2. No need to assign default gateway and DNS. 3. Assign static IP on pc 2 as 192.168.1.3 assign subnet mask as 255.255.255.0. 4. No need to assign default gateway and DNS.
Open dos and try to ping. In case if the ping fails then disable all the firewall on both the pc's and try again.
If you are running windows vista then in network and sharing center make sure network discovery and file sharing is enabled.
Regards,
Rashish
Aug 06, 2010 | Accton CheetaHub Classic 2040 Networking...
Staus led not blinking after a fw update
You are going to have to find a software that helps you force reinstall the Firmware. Something went wrong somewhere, I know the software exists, i used it to install a 3rd Party Firmware on my linksys to gain Access Point Functionality
Apr 14, 2010 | D-Link AirPlus DI-524 Wireless Router
I am trying to set up a wireless network. Trendnet TEW-652BRP router. Book says to go to 192.168.10.1? I get INternet Explorer cannot display them webpage. i went to run>cmd ping 192.168.10.1 Request...
open up command prompt (run--> cmd) and type in "ipconfig" (without quotes). Look for the folowing: Default Gateway: 192.168.something.something Open up internet explorer and go to that 192.168.something.something instead of going to 192.168.10.1
You should be able to finish configuration from here. Also, you have to be connected to the router, either wirelessly or with a cable in order to access the settings, double check your connection.
Good luck
Dec 28, 2009 | Trendware TEW-652BRP Router
Cannot ping to default gateway
now u need to reset it .
Check in back side of your modem u find 1 reset button press it for 10 seconds then it reset to factory defaults.then u cana cces it with 192.168.1.1
or 192.168.0.1
May 05, 2009 | Computers & Internet
Voyager A210 Laptop shows when connected to wifi "Limited or no connectivity"although others are connected on same router at the time. I have removed wifi program and reinstalled No difference
This is just a try. Find out the Default Gateway on the other computers. If they are using a static IP then you need to get on. At someone else's computer click Start and Run and enter Cmd and click OK.
Now type in ipconfig /all. Look for IP Address, Subnet Mask, Default Gateway and DNS Servers. Write it all down. Then find an available IP address by using the Ping command.
In the same Window, type in ping and the IP Address of the computer you are at. That's just to show you what it looks like when you find an IP already taken. You'll see "reply from..." with the address you just pinged. Now ping again but change the last octal in the IP (the last number) in the IP address to something under 256. And ping again. Do this until you get a message "request timed out". You've just found an available IP.
Mar 27, 2008 | Computers & Internet
Internet connection
So you have your computer wired to a router, isn't it? Try opening the CMD and input ping 192.168.1.1 (this is the default address for a router, if you had changed it for some reason then you should type ping 'default address' ) and you should see something like "reply ...". If you see something like "request timed out" then reset the router to factory defaults. Try pinging again your router, if you still see "request time out" then theres a hardware error on either the computer or the router.
Hope this works!
Feb 16, 2008 | Computers & Internet
Cannot connect second computer to my networn
I have listed several things here that you can use to find the problem. Sorry this is so long...network problems can be very tedious to find.
First check your version of Windows:
Double click on "My Computer", then click on "View System Information" to make sure you have at least Service Pack 1...or better yet....Service Pack 2.
Next check your Windows XP network settings:
Click on Start....Control Panel....Network Connections...Local Area Connection...Properties(button). Scroll down the list to find Internet Protocol(TCP/IP) and click on it to highlight it. Now click the properties button below the list. You should now be able to click the small buttons to select both of the "Obtain....automatically" choices for IP address and DNS server. Click on "OK" to close each of the windows.
Now you can test your computer to see if it is "talking" to the router: Click on Start...Run...and type "cmd" in the small box and click "OK". This will open a black command window where you tell the computer what to do. Type the command "ipconfig" and press return (enter). This will list your ip address, subnet mask, and default gateway. Make a note of the default gateway address so you can use it for the next test. If the IP address begins with 192.168...then your computer is probably communicating with the router okay. If your IP address is blank or starts with 169...then your network connection to the router may NOT be working.
The final test!!! Use the default gateway address from the last step to do a "ping" test. In the black command window...type "ping" followed by the default gateway address. For example: IF the default gateway happens to be 192.168.1.1....then type the ping command this way: ping 192.168.1.1
If the result is a list of replies from the gateway address...great!! Your network connection is working. If the ping command results in a list of "request timed out", or something else, then your network connection needs more help.
The ultimate test is to try using the Internet with your browser.
If this works, next try typing your gateway address into the brower address bar. It should connect you to the router setup page.(?)
Let me know the results of each of these tests, and I'll be happy to assist you further, if needed.
Jan 12, 2008 | Computers & Internet
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
229 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
