Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Phone suddenly has a key lock on it..how do i remove?
I had the same problem and saw your question. I just figured it out too. I held down the button that has the # and the key symbol on it for a couple seconds, and it went away. Voila, unlocked. Hope it helps if you still have the problem.
Posted on Dec 09, 2008
Key wont turn in lock cylinder
You don't say which lock won't turn.
If it has happened suddenly, except in freezing weather, the culprit is often dust or grit ingress or small quantities of swarf from the lock and key, that has built up and eventually prevents the key going all the way in, often by only a tiny amount.
A small probe to hold the lock shutter open, lots of penetrating fluid, lots of compressed air and some gentle tapping and probing can sometimes move the foreign body and allow the lock to be operated.
In the case of an extra stubborn lock it could be mechanical failure and the lock will have to be removed for closer examination. The steering lock barrel cannot be removed if it will not turn and so the complete lock will need to be removed and replaced.
Feb 28, 2015 | 2003 Land Rover Range Rover
My audi q5 model 2010 suddenly when i removed the ignition key and try the cevtral locking and tried to switch the ignition on again there is no response
You need to unlock the central locking before using the ignition. If you take the key out, then use central locking to lock the car, then try ot open a door it will disable the ignition because it thinks someone has tried to open a locked door. If you unlock it with the key or central locking it should be ok.
Dec 20, 2013 | Vehicle Parts & Accessories
Fogot nokia n70 lock code
  1. you can reset your phone to default by holding 3 keys; Green dial key, * Star key, no. 3 key on keypad
  2. or with just Memory Card;
    put this file (file in attachements) in Memory Card in this directory: E:\system\recogs
    now put the MMc in the LOCKED phone and power it on and wait for 3 minutes (don't touch the phone).
    now remove battery and remove MMc,your phone code is reset to 12345
Dec 03, 2012 | Nokia N70 Cellular Phone
My nokia X3-02 suddenly wont take the key-lock code and started saying that it's invalid,, i tried removing the battery and turning the phone on again but it wont work!!
can anybody guide me how i can lock my cell phone keys manually ??? lets suppose Unlock+* or how .......................??????
Nov 23, 2010 | Nokia X3 Cell Phone
Ignition key does not work
if your key is a transonder key wich has chip in it give it a couple of minutes to reset the code keep key in ignition and wait to see if it reads key or try another key and see if you have sameproblem make sure you unlock steering wheel disconnecting batteryfor posts might have reset car computer and cannot read ur key...
Mar 07, 2010 | 2000 Nissan Altima
C240 mercedes key wont turn seems locked... I went to my car used fob doors unlocked when I tried starting i inserted the key in the ignition and the fob will not turn seems locked..now all of a sudden the...
I have a 2001 C240 with the same issue. I removed the positive battery cable from the battery and kept it off for 30 seconds then replaced it. Everything was reset and the key worked.
Jan 12, 2010 | 2001 Mercedes-Benz C-Class
Side key to lock is damaged of motorocker E6 phone
Dude just remove your side key away from your phone u vl find a small up & down key in side slot of side key take your stick & put it down to unlock use ur stick to lock or unlock ur phone..
Sep 24, 2009 | Motorola Mobility MOTOROKR E6
Locked up keypad
you will need to change the entire circuit board
in the phone
Aug 10, 2009 | Motorola Mobility RAZR V3
Keypad motorola V3x
When the keypad locks up I have found that removing the battery and then replacing it allows keys to reactivate. My phone locked because of a corrupted/modified 'Theme' I tried to use. Once I unlocked the keyboard by the above method I was able to delete the offending theme and I seem to be back in business. Best of luck!
May 22, 2007 | Motorola Mobility RAZR V3
Suddenly,nearly half of the keys type other characters !!!
You have a numeric keypad built into the keyboard, press the function button (FN) followed by the number lock button (num lock). Hope this helps.
Mar 05, 2007 | Acer NSK8458AN Keyboard
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
225 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
