Question about Samsung SyncMaster 740N 17" LCD Monitor
Syncmaster710N Is making a humming noise. what can i do to stop it &/or what is causing it
    Problem Solver:
  • 16 Answers
There are no speakers attached but if for any reason humming is comming its the transformer inside the casing. Very comming in transformers that after some time they start humming noise.Its not for all of them but its some coiling fault but it doesn't effect anything.
Posted on Jul 28, 2008
  • Saad Nawaz Aug 29, 2008
    this humming noise can be your lcd tubes aswell..... this can be checked if reduce/increase brightness of monitor.. if there is change in the intensity of noise... but transformer is still the culpret.
4x4. What causes humming sound?
The used tires may be unevenly worn.
Jan 26, 2016 | 2007 Ford Explorer Sport Trac
Can cv joints cause noise when braking
No really because there is pressure both ways keeping them from making noise. Usually they make noise when turning(clicking type noise) or them hum at higher speeds. This also sounds like bearing noise. The way to tell the difference is bearing noise will get loader or softer when your are making turns. Axles will have a consistent noise to them. Now bearings will make a noise when stopping.
Mar 01, 2015 | Cars & Trucks
Whirlpool Dryer made loud humming noise and quit
Something caused the motor to lock up. The humming noise was the start winding in the motor trying to start rotation, but could not because of lockup. The humming noise stopped when the start winding burned out ( will only last 6 or 7 seconds). It will require a new motor, plus repair to whatever caused it to lock up in the first place.
Dec 22, 2013 | Dryers
Humming noise when i turn the key on in the morning
power steering pump make humming noise and alternator with bad shaft bearing make noise.
Feb 12, 2013 | 2005 Toyota Sequoia SR5
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Dryer motorstuck.. itself.. work'sometime.. but stop with the humming soung the is some smoke .. please solve it..
hiMotor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.
The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
Sep 13, 2008 | Kenmore 63942 Dryer
Maytag MDB5000AWW started making noise when cleaning. Bottom arm working , but water isn't pumping with much force. No water coming out of top hole (removed arm to make sure there is no obstructions. ...
HI Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Sep 12, 2008 | Maytag Dishwashers
Maytag Neptune Dryer Model # MDE3000AYW
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Sep 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Samsung SyncMaster 740N 17" LCD Monitor Logo
340 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
