Question about BenQ PB6210-DLP PROJECTOR XGA Multimedia Projector
How do I reset lamp hrs on benq 6210 - BenQ PB6210-DLP PROJECTOR XGA Multimedia Projector
    Sniper:
  • 59 Answers
Resetting the lamp counter
i. Press and hold the Exit 5 button on the projector for 5
seconds to display the total used lamp time.
ii. Press Auto on the projector or on the remote control to
reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
Posted on Feb 14, 2011
SOURCE:
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
I have a BenQ PB 6210. After switching it on, it first displays that the lamp has run 2001 hours and should be replaced. After this window disappears, it takes maybe 2 seconds and the projector shuts...
Hi cholthusen,
Please be informed that the average lifespan of a projector's lamp is around 2000 hours. The light bulb is almost certainly the problem. The best solution would be to change the bulb. The easiest way to do that is to change the lamp assembly (fresh bulb is in the new assembly). You may also try resetting the unit. Turn the unit off, then physically remove the power cord. wait for about 10-15 seconds then start it back again. If this did not work, please replace the lamp.
Hope it helps.
Thank you for using FixYa.
Jun 23, 2011 | BenQ PB6210-DLP PROJECTOR XGA Multimedia...
Reset the lamp hrs. of pb6210
Press and hold the Exit button on the projector for 5 seconds to display the total used lamp time.
Press Auto on the projector or on the remote control to reset the lamp hour to "0".
Mar 25, 2011 | BenQ PB6210 Multimedia Projector
How to reset lamp hrs.
hi
you can reset the lamp hour by the following settings
1.Power on the projector
2.Press the EXIT button on the projector for 3 second to display the total used lamp time
3.Press the MENU button on the projector (adjustment message will appear
4.Press the LEFT ARROW or RIGHT ARROW button to to reset the lamp hour
5.Press the EXIT button
ok
Jan 18, 2011 | BenQ PB2220 Multimedia Projector
Projector turns on. The blue screen comes on. After the ben Q symbol disapears a warning measage comes up 2004 hrs, change bolb if not bright. Then picture disapears and the temp light comes on! Any...
hi,
its because ur lamps life comes on its end. its time to replace the lamp. after replacing u should rest the lamp timer to zero. if u have already replaced the lamp do the following,if not also.
1 Press and hold the Exit (up arrow) button on the projector for 5
2.Press Auto button the projector or on the remote control to
3. Wait about 5 seconds to let the OSD disappear.
ok
Dec 22, 2010 | BenQ PB6110 Multimedia Projector
Benq PB8220 lamp used for 375 hrs shuts projector automatically
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
Replacing the lamp
We contacted BenQ's technical service people from the toll free number on their website. They had us do the same thing the manual said to do and of course the lamp hours would not reset. We had to send the projector to them and they responded that our mother board went and that it needs to be replaced. They've quoted us around $180. What happened to us was that we didn't change the bulb when the warnings came up on the screen. It isn't explained anywhere that if you wait til you get to 3000 hrs without changing the bulb that you could screw up your machine, but it's kind of looking that way. If I were you guys, I would make that call to their tech support and see what they tell you.
Aug 29, 2008 | BenQ PE5120 Multimedia Projector
Light hours getting close to 3000, but picture still looks good,will resetting lamp hour hurt and keep using same lamp be ok. thanks david
No do not reset the lamp hrs. because the lamp might reach the ed of life and could blow resulting in mercury poisoning. If you notice there is a warning sign that pops up in red or something saying to change the lamp, it will shut down eventually during that warning time. You have gotten a lot of hours with that lamp and consider being fortunate to have such reliability. Buy a new lamp when needed as it will improve your experience.
Jul 04, 2008 | BenQ PB6100 Multimedia Projector
Reset after lamp replacement
benq mp610. press EXIT button for five sec. you see counter hrs. then press AUTO button to reset
Oct 13, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
REPLACING MY LAMP
Hi Big Dogg
Replace the lamp and reset the lamp timer.
Lamp timer can be reset by holding down the up arrow key and then following the easy on-screen instructions.
Sep 14, 2007 | BenQ MP610 Multimedia Projector
584 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Marvin
Marvin
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
