Question about HP Photosmart 4180 All-in-One Printer
Carriage jam HPC4180 ALL IN ONE ERROR HOW DO I CLEAR A CARRIAGE JAM
  • 5 more comments
  • tgilray Jul 28, 2008
    I keep getting the error signal that the carriage is jammed. How do I fix it?
  • Anonymous Oct 14, 2008
    everything i try doesn't work. i don't even know what the carriage is! please help, it's so frustrating being without a printer!
  • Anonymous Nov 22, 2008
    same carriage jam unable to clear problem
  • Anonymous Dec 20, 2008
    cant clear carriage jam
  • bevsmed Jan 04, 2009
    I have a carriage jam and I don't know where the carriage door is
  • Anonymous Feb 17, 2009
    Two printers. Same problem. No known event prior to error message. Power reset, reseating cartridges did not "fix" problem. Cannot spend too much time working on units due to new printer costs, but not good. I assume a sensor is broke or something obstructing view of sensor.
  • jfingland May 11, 2010
    How do I clear a carriage jam?
  • 3 Answers
Assuming that you have ruled out strictly mechnical issues, the next common problem in my experience is the optical encoder system. Most HP inkjets have a long, thin optical encoder strip that the moving carriage reads to determine its position. This plastic strip runs the width of the printer inside, usually behind the carriage. Several problems can occur -- one, it can become broken or pulled off of its mounting tabs at each end, two, over time it can become very dirty with stray ink. Stray ink can also obscure the optical sensor in the carriage that reads the strip.
There is a similar one elswhere in the printer, but in the form of a wheel or disc. This is how the printer determines movement of the paper through the machine. Usually this one can be obstructed by paper chaff over time, or stray ink build up. Since it isn't a long strip, it rarely is a mechanical issue with the encoder wheel.
In any event, failure of this device for any reason means the printer loses track of the print carriage movement and thus can report a "carriage jam" error. Inspection and cleaning of this can fix this problem, if there are no other obvious mechanical issues that jam the carriage (like a stray piece of paper inside, etc.).
Posted on Aug 20, 2009
    Genius:
  • 2,785 Answers
Plz resit the cartridge, if the problem persists than you have to send it for repair
Posted on Jul 24, 2008
Carriage jam
cannot print, msg shows Error carriage jam, Open door, clear carriage jam, and then press o.k. to continue.
paper has been cleared , opened door and even took off back compartment
Dec 22, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Clear carriage jams
use some lubricant or oil (minimum) for cartridge rail
Feb 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Jan 21, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 4180 All-in-One Printer Logo
611 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
