Question about Epson Stylus Photo R220 InkJet Printer
Red ink problem
Cannot print red but everything else prints
  • 446 Answers
Red is the combination of Yellow and Magenta toner, try printing one of each independently, if either is printing correctly yellow and magenta you should be able to print red. good luck
Posted on Jul 24, 2008
SOURCE: epson stylus dx4050
epson printers will stop printing if any of the colours run out, replace the colour cartridge and it should be fine
Posted on Jan 19, 2009
SOURCE: Kodak Printer will not Print Red Ink
I have problems printing red ink too. What can I do to resolve this and how can I purchase a new Printhead to see if this is the problem?
Posted on Mar 07, 2009
gwbm
  • 353 Answers
SOURCE: Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Posted on Mar 12, 2009
  • 220 Answers
SOURCE: won't print
download smartpanel for this model from samsung web,install on pc,will tell you what the problem is.
Posted on Jun 24, 2009
  • 40 Answers
SOURCE: red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Posted on Aug 01, 2009
How do I get the printer to print when it only has the blk ink cartridge that is new and the color ink is running out. It prints everything red. What do I do?
Get new color cart. Most inkjet printers will not print anything if one of the carts is empty.
As for printing everything red, that is a different issue. Your printer setup screen in the computer may have a "black only" setting.
Nov 09, 2015 | Cannon Office Equipment & Supplies
Why does epson workforce 635 print emails in red
Hi Sal Lentz, try this:
1. Copy the message to word pad and print, if ok.
2. Check the printer properties from your web page.
Aug 21, 2014 | Office Equipment & Supplies
Poor print quality
Try printing a test page, which shows a sample of the colors in the ink cartridge individually, usually yellow, cyan and red. It may be that the blue ink is getting low. You did not say whether you were printing text (black) or photos (color).
Oct 26, 2013 | Epson PRINTER,ARTISAN 730
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
The color red will not print on My Dell A940 printer.
Try find another printer(same model- says printer B)...take printer head from printer B to your printer(says printer A),use your ink cartridge and test your printing....if all color seen on paper, then the problem is your printer head, to make sure is it true or not, use printer head from printer A into printer B.see the result...
May 26, 2009 | Dell A940 All-In-One InkJet Printer
RED INK
what do you mean? when every you print any picture in word, then it print in red? did u check ur ink, i think u have only red ink is left so plz check the color. ok
May 12, 2009 | Canon Pixma MP500 All-In-One InkJet...
Dec 30, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
All colors not printing
hi this is nichu, you have done everything correct but the ink is low in your catridges refill it or purchase a new one.
Nov 20, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Red colour prints brown
Just replace the non genuine inks with proper Canon ones and then do about 4 full cleans, that should fix it. If not you will have to replace the printhead, which is usually caused by using non genuine ink. Good luck
May 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Stylus Photo R220 InkJet Printer Logo
375 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
