Question about Lexmark T640 Laser Printer
917.00 srvice transfer roller
I have two t640 lexmarks that have this problem. when i shut off and clean the transfer roller they will work fine for 3 to 4 weeks and then it will happen again. any suggestions
  • 1 more comment
  • biapro-info Feb 04, 2009
    i did change the transfer roller still give's this error
  • harval Feb 10, 2009
    I have fitted the new Maintenance kit, reset the Maintenance count but the error still displays
  • Anonymous Mar 06, 2009
    917.00 service transfer roll
    Scholar:
  • 136 Answers
1) How many pages per month do you print?
2) How long have you owned the printers?
3) Possibly just need to order a maint. kit depending on answers.
Let me know!
Posted on Jul 24, 2008
What is the service transfer roll? What does it look like? How do I replace it for the classroom printer?
Most often caused by high voltage power supply caused by toner spill. It is located bellow the transfer roller under the paper guide.
Oct 18, 2013 | Lexmark T640 Laser Printer
Service transfer roll
Hi, The transfer roller is the roller located untherneath the tonercartridge. Partnumber 40X0130
Printer displays 917.00 print error. seems to be transfer roller. changed the transfer roller same error.
The exact definition of this error is "Problem with transfer-transfer servo start error"... NOT the transfer roller. The service manual directs you to the Transfer roll service check.
The service check tests for proper operation of the HVSP, system board, and sensors.
The most likely cause of your problem is the HVSP ( High Voltage Power Supply ).
Change the HVPS and you should be good to go!
Feb 28, 2011 | Lexmark T640 Laser Printer
I am getting dirty copies. How do I clean rollers?
Here's an article in the Lexmark website on How to Check the Paper Tray Feed Rollers on a Lexmark T640, T642, or T644 Printer. Just click on this link: http://bit.ly/b71goj. Follow the instructions carefully. Hope this helps.
Jun 24, 2010 | Lexmark T644 Laser Printer
Lexmark T640 Error 917.00, I have changed the
you need to change the high voltage power supply to fix this error i have found this to be the problem 98% of the time and i do csome 1200+ repairs on these printers a year
Nov 27, 2009 | Lexmark T640 Laser Printer
917.00 service trasfer roller
That transfer roller is available at www.precisionroller.com for $39.95
Sep 25, 2009 | Lexmark T640 Laser Printer
Error code 917.00 "service transfer roller" won't clear
This is a transfer roll error. Take the toner cartridge out and clean the area under it. The transfer roll is a roller which is right under the toner cartridge. make sure the ie is clean . It may need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 30, 2009 | Lexmark T640 Laser Printer
Lexmark T640, 242.10 jam error
Please go www.lexmark.com >>Technical Support.
Place the T640 model number into the first search box. When the T640 block opens up do a search for "ENUS23982."
Don
Jun 10, 2009 | Lexmark T640 Laser Printer
Lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
May 07, 2009 | Lexmark T642 Laser Printer
Print quality on Lexmark T640
There are 2 likely possibilities:
1. Very dark print usually indicates your charge roller is not removing the charge from the drum.
The charge roller "erases" the charge laid down by the laser from the previous pass and prepares it for the next portion of the image. If not erased or has a latent charge it will pull toner onto the drum. Try changing the charge roller . 2. Your wiper blade in the cartridge may not be properly wiping excess toner. Swap the toner cartridge with another and see if the problem goes away.
There is a video here you can watch on changing the charge roller:
http://www.fastprinters.com/TechSupport_repair_parts.asp#T640VIDEO
Mar 24, 2009 | Lexmark T640 Laser Printer
Lexmark T640 Laser Printer Logo
1,323 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
